Video 35: Plant Monitor
This tutorial demonstrates how to build a smart plant monitoring system using an ESP32 board, which measures temperature, humidity, soil moisture, and light, and displays the data on an LCD. It also includes a manual water pump control feature.
Comprehensive Monitoring: Utilizes DHT11, soil moisture sensor, and LDR to monitor plant health indicators.
LCD Display Integration: Shows real-time data readings on an LCD screen for easy monitoring.
Water Pump Control: Includes a manual push button to activate a water pump for plant watering.
ESP32 and Component Overview: Explains the functionality of each component and their integration.
Practical Demonstration: Shows the system in action, providing a clear example of its capabilities.
Arduino Code and Setup: Walks through the Arduino code required for the project, including setup and sensor readings.
Video
