ESP32 Camera Extension
We have designed an expansion board that enables you to fully utilize the camera and SD card functionalities of the ESP32 WROOM 32E. By combining the OV2640 camera, Micro SD, and ESP32 WROOM 32E, you get an all-in-one expansion board.
The board provides two types of GPIO headers - one with female headers, perfect for quick prototyping projects. The other type features screw terminals, ensuring stable wire connections and making it suitable for IoT projects.
Additionally, you can power your project using a single 3.7V battery. If the battery runs low, you can conveniently charge it by simply plugging in a 5V Micro USB cable. This makes it a great tool for outdoor projects and remote applications.
Specification Table
Parameter |
Minimum Value |
Typical Value |
Maximum Value |
Unit |
Battery Shutdown Current |
60 |
uA |
DC-DC Output Voltage |
4.9129 |
5.0889 |
V |
DC-DC Overtemperature Protection |
150 |
Battery Charging Current |
500 |
mA |
Charging Overtemperature Protection |
130 |
Input Low Voltage Switching Threshold |
3.4 |
V |
Interface Introduction
- Power Switch
Controls the battery’s power supply, toggling it on and off.
- Charging Port
Upon connecting a 5V/0.5A Micro USB cable, the battery can be charged.
- Battery Port
Features a PH2.0-2P interface, compatible with 3.7V lithium batterry.
Provides power to both the ESP32 WROOM 32E and ESP32 Camera Extension.
- ESP32 Pin Headers
Intended for the ESP32 WROOM 32E module. Pay close attention to its orientation; ensure both Micro USB ports face the same side to avoid incorrect placement.
- GPIO Headers
Female Headers: Used to connect various components to the ESP32, perfect for quick prototyping projects.
Screw Terminal: 3.5mm pitch 14pin screw terminal, ensuring stable wire connections and making it suitable for IoT projects.
- Indicator Lights
PWR: Lights up when the battery is powered or when a Micro USB is directly plugged into the ESP32.
CHG: Illuminates upon connecting a Micro USB to the board’s charging port, signifying charging onset. It will turn off once the battery is fully charged.
- Micro SD Connector
Spring-loaded slot for the easy insertion and ejection of Micro SD card.
- 24-pin 0.5mm FFC / FPC connector
Designed for the OV2640 camera, making it suitable for various vision-related projects.
Pin Mapping Tables
The ESP32 WROOM 32E’s pinout diagram can be found in Pinout Diagram.
However, when the ESP32 WROOM 32E is inserted into the extension board, some of its pins may also be used to drive the Micro SD card or a camera.
Consequently, pull-up or pull-down resistors have be added to these pins. If you’re using these pins as inputs, it’s crucial to account for these resistors as they can affect input levels.
The onboard 8M PSRAM provides ample RAM for the camera. PSRAM occupies IO16 and IO17. Therefore, the expansion header and expansion screw terminal do not extend IO16 and IO17.
Here’s the pinout table for the right-side pins:
Here’s the pinout table for the left-side pins:
Micro SD Connector Pin Mapping Table
Micro SD Connector |
ESP32 |
D0 |
IO2 |
D1 |
IO4 |
D2 |
IO12 |
D3 |
IO13 |
CLK |
IO14 |
CMD |
IO15 |
FFC / FPC Connector Pin Mapping Table
The camera interface mainly uses the OV2640, compatible with the 8225 camera. The interface adopts an FFC connector with a 0.5mm pitch 24P flip-down connection.
Number |
FFC / FPC Connector |
ESP32 |
Y0 |
NC |
Y1 |
NC |
Y4 |
IO19 |
Y3 |
IO18 |
Y5 |
IO21 |
Y2 |
IO5 |
7 |
Y6 |
IO36 |
8 |
PCLK |
IO22 |
9 |
Y7 |
IO39 |
10 |
DGND |
GND |
11 |
Y8 |
IO34 |
12 |
XCLK |
IO0 |
13 |
Y9 |
IO35 |
14 |
DOVDD |
3.3V |
15 |
DVDD |
1.2V |
16 |
HREF |
IO23 |
17 |
PWDN |
IO32 |
18 |
VSYNC |
IO25 |
19 |
RESET |
IO33 |
20 |
SIO_C |
IO27 |
21 |
VADD |
2.8V |
22 |
SIO_D |
IO26 |
23 |
AGND |
GND |
24 |
NC |
NC |
Interface Insertion Guide
Upload Code
Inserting the Micro SD Card
Attaching the Camera
When connecting the camera, ensure the black stripe of the FPC cable is facing upwards and is fully inserted into the connector.
