.. include:: /index.rst :start-after: start_hello_message :end-before: end_hello_message 1. What Else Do You Need? =============================== Before we start using this screen, let’s prepare the essential hardware. Required Components ------------------------------ * **Raspberry Pi** * **Compatible models**: Raspberry Pi 5, Raspberry Pi 4 Model B * Other Raspberry Pi models are not supported. .. image:: img/need_pi.jpg * **Power Adapter** Different Raspberry Pi models require different power supplies. For best stability, it is recommended to use the official power adapter: * **Raspberry Pi 5**: Recommended: **5V 5A USB-C power supply** (Official 27W PSU). You may also use a USB-C Power Delivery (PD) charger, as long as it provides sufficient current. * **Raspberry Pi 4 Model B**: Recommended: **5V 3A USB-C power supply** (Official 15W PSU). You may also use a USB-C PD or QC 2.0 fast charger. .. image:: img/need_power.png :width: 400 * **Micro SD Card** The Raspberry Pi does not include built-in storage. It boots and stores all data on a **Micro SD card**. .. image:: img/need_sd.jpg :width: 200 * Minimum: **16GB** * Recommended: **32GB** or higher for better performance and stability * Recommended brands: **SanDisk**, **Samsung** Optional Components ------------------------ Although not strictly required, the following peripherals will significantly improve your setup and debugging experience: * **Monitor (HDMI or TV)** For beginners, we strongly recommend using a display with an HDMI input. This makes it easier to configure the system and run graphical programs. .. image:: img/need_screen.png :width: 400 * **Micro HDMI Cable** * The Raspberry Pi 4B and Raspberry Pi 5 require a **Micro HDMI cable** to connect to a display. * It is recommended to use the **HDMI0 port** (the one closest to the USB-C power port). .. image:: img/need_hdmi.png :width: 400 * **Keyboard & Mouse** * These are very useful during the initial OS setup. * You can switch to remote access (SSH/VNC) later, but for beginners, a basic USB or wireless keyboard and mouse are highly recommended. .. image:: img/need_keyboard_mouse.png :width: 500
