Remote Desktop
There are two ways to control the desktop of the Raspberry Pi remotely:
VNC and XRDP, you can use any of them.
VNC
You can use the function of remote desktop through VNC.
Enable VNC service
The VNC service has been installed in the system. By default, VNC is disabled. You need to enable it in config.
Step 1
Input the following command:
sudo raspi-config
../_images/image287.png
Step 2
Choose 3 Interfacing Options by press the down arrow key on your keyboard, then press the Enter key.
../_images/image282.png
Step 3
P3 VNC
../_images/image288.png
Step 4
Select Yes -> OK -> Finish to exit the configuration.
../_images/image289.png
Login to VNC
Step 1
You need to download and install the VNC Viewer on personal computer. After the installation is done, open it.
Step 2
Then select “New connection”.
../_images/image290.png
Step 3
Input IP address of Raspberry Pi and any Name.
../_images/image291.png
Step 4
Double click the connection just created:
../_images/image292.png
Step 5
Enter Username (pi) and Password (raspberry by default).
../_images/image293.png
Step 6
Now you can see the desktop of the Raspberry Pi:
../_images/image294.png
That’s the end of the VNC part.
XRDP
Another method of remote desktop is XRDP, it provides a graphical login to remote machines using RDP (Microsoft Remote Desktop Protocol).
Install XRDP
Step 1
Login to Raspberry Pi by using SSH.
Step 2
Input the following instructions to install XRDP.
sudo apt-get update
sudo apt-get install xrdp
Step 3
Later, the installation starts.
Enter “Y”, press key “Enter” to confirm.
../_images/image295.png
Step 4
Finished the installation, you should login to your Raspberry Pi by using Windows remote desktop applications.
Login to XRDP
Step 1
If you are a Windows user, you can use the Remote Desktop feature that comes with Windows. If you are a Mac user, you can download and use Microsoft Remote Desktop from the APP Store, and there is not much difference between the two. The next example is Windows remote desktop.
Step 2
Type in “mstsc” in Run (WIN+R) to open the Remote Desktop Connection, and input the IP address of Raspberry Pi, then click on “Connect”.
../_images/image296.png
Step 3
Then the xrdp login page pops out. Please type in your username and password. After that, please click “OK”. At the first time you log in, your username is “pi” and the password is “raspberry”.
../_images/image297.png
Step 4
Here, you successfully login to RPi by using the remote desktop.
../_images/image20.png
Copyright Notice
All contents including but not limited to texts, images, and code in this manual are owned by the SunFounder Company. You should only use it for personal study, investigation, enjoyment, or other non-commercial or nonprofit purposes, under the related regulations and copyrights laws, without infringing the legal rights of the author and relevant right holders. For any individual or organization that uses these for commercial profit without permission, the Company reserves the right to take legal action.
