On-Board MCUο
The Robot HAT comes with an AT32F413CBT7 microcontroller from Artery. It is an ARM Cortex-M4 processor with a maximum clock frequency of 150MHz. The microcontroller has 256KB of Flash memory and 32KB of SRAM.
The onboard PWM and ADC are driven by the microcontroller. Communication between the Raspberry Pi and the microcontroller is established via the I2C interface. The I2C address used for communication is 0x14 (7-bit address format).
Introduceο
The on board MCU RESET pin is connected to Raspberry Pi GPIO 5, or MCURST for robot_hat.Pin. The MCU using 7-bit address 0x14.
ADCο
Register addresses is 3 byte, 0x170000 to 0x100000 are ADC channels 0 to 3 (5-7 not used).
The ADC precision is 12 bit, and the value is 0 to 4095.
See more details in robot_hat.ADC.
Address |
Description |
ADC channel 0 |
ADC channel 1 |
ADC channel 2 |
ADC channel 3 |
ADC channel 4 (Battery Level) |
Example:
Read Channel 0 ADC value:
from smbus import SMBus
bus = SMBus(1)
# smbus only support 8 bit register address, so write 2 byte 0 first
bus.write_word_data(0x14, 0x17, 0)
msb = bus.read_byte(0x14)
lsb = bus.read_byte(0x14)
value = (msb << 8) | lsb
PWMο
PWM have 1 byte register with 2 byte values.
Changing PWM Frequencyο
Frequency is defined with prescaler and period.
To set frequency first you need to define the period you want. Like on Arduino, normaly is 255, or like PCA9685 is 4095.
CPU clock is 72MHz, Then you can calculate the prescaler from your desire frequency
prescaler = 72MHz / (Period + 1) / Frequency - 1
Or if you donβt care about the period, thereβs a way to calculate both period and prescaler from
frequency. See robot_hat.PWM.freq().
Pulse widthο
To control the channel pulse width is rather simple, just write the value to the register.
But what is the value? If you want to set the PWM to 50% pulse width, you need to know exactly what the period is. Base on the above calculation, if you set the period to 4095, then set pulse value to 2048 is about 50% pulse width.
Address |
Description |
Set PWM channel 0 On Value |
Set PWM channel 1 On Value |
Set PWM channel 2 On Value |
Set PWM channel 3 On Value |
Set PWM channel 4 On Value |
Set PWM channel 5 On Value |
Set PWM channel 6 On Value |
Set PWM channel 7 On Value |
Set PWM channel 8 On Value |
Set PWM channel 9 On Value |
Set PWM channel 10 On Value |
Set PWM channel 11 On Value |
Set Motor 1A (PWM12) On Value |
Set Motor 1B (PWM13) On Value |
Set Motor 2A (PWM14) On Value |
Set Motor 2B (PWM15) On Value |
Set Motor 3A (PWM16) On Value |
Set Motor 3B (PWM17) On Value |
Set Motor 4A (PWM18) On Value |
Set Motor 4B (PWM19) On Value |
Prescalerο
Register from 0x40 is to set the PWM prescaler. ranges from 0~65535. There are 7 timers for all channels. See PWM Timer
Address |
Description |
Set timer 0 Prescaler |
Set timer 1 Prescaler |
Set timer 2 Prescaler |
Set timer 3 Prescaler |
Set timer 4 Prescaler |
Set timer 5 Prescaler |
Set timer 6 Prescaler |
Periodο
Register from 0x44 is to set the PWM period. ranges from 0~65535. There are only 7 timers for all channels. See PWM Timer
Address |
Description |
Set timer 0 Period |
Set timer 1 Period |
Set timer 2 Period |
Set timer 3 Period |
Set timer 4 Period |
Set timer 5 Period |
Set timer 6 Period |
PWM Timerο
What is PWM Timer? PWM Timer is a tool to turn on and off the PWM channel for you.
The MCU only have 7 timers for PWM: which means you cannot set frequency on different channels at with the same timer.
Example: if you set frequency on channel 0, channel 1, 2, 3 will be affected. If you change channel 2 frequency, channel 0, 1, 3 will be override.
This happens like if you want to control both a passive buzzer (who changes frequency all the time) and servo (who needs a fix frequency of 50Hz). Then you should seperate them into two different timer.
Timer |
PWM Channel |
Timer 0 |
0, 1, 2, 3 |
Timer 1 |
4, 5, 6, 7 |
Timer 2 |
8, 9, 10, 11 |
Timer 3 |
12, 13, 14, 15 |
Timer 4 |
16, 17 |
Timer 5 |
18 |
Timer 6 |
19 |
Set PWM Timerο
bus = SMBus(1)
# Set timer 0 period to 4095
bus.write_word_data(0x14, 0x44, 4095)
# Set frequency to 50Hz,
freq = 50
# Calculate prescaler
prescaler = int(72000000 / (4095 + 1) / freq) - 1
# Set prescaler
bus.write_word_data(0x14, 0x40, prescaler)
# Set channel 0 to 50% pulse width
bus.write_word_data(0x14, 0x20, 2048)
Reset MCUο
Currently the firmware reads a fix 3 byte value, then it can return ADC values or control PWM. Thats why ADC register need 3byte with the latter 2 byte is 0.
And if your program is interrupted in the middle of the communication, the firmware may stuck and offset the data. Even we have timeout on waiting on 3 byte datas.
If so, you need to reset the MCU. To reset it. You can use the robot_hat command:
robot_hat reset_mcu
Or you can do it in your python code:
from robot_hat import reset_mcu
reset_mcu()
Or you can just pull down the reset pin (GPIO 5) for 10 ms, then pull it back up for another 10ms, as thatβs what reset_mcu dose.
import RPi.GPIO as GPIO
GPIO.setmode(GPIO.BCM)
GPIO.setup(5, GPIO.OUT)
GPIO.output(5, GPIO.LOW)
time.sleep(0.01)
GPIO.output(5, GPIO.HIGH)
time.sleep(0.01)
