πŸ‘‰ Ready to explore and create with us? Click [here] and join today!
Hardware Introduction
Pinout
../_images/robohat_pinout_v5.png
Power Port
  • 6.0V-8.4V XH2.54 3pin power input.
  • Powering the Raspberry Pi and Robot HAT at the same time.
Power Switch
  • Turn on/off the power of the robot HAT.
Type-C Charge Port
  • Insert the Type-C cable to charge the battery.
  • At the same time, the charging indicator lights up in red color.
  • When the battery is fully charged, the charging indicator turns off.
  • If the USB cable is still plugged in about 4 hours after it is fully charged, the charging indicator will blink to prompt.
Digital Pin
ADC Pin
PWM Pin
Motor Port
I2C Pin and I2C Port
  • I2C Pin: P2.54 4-pin interface.
  • I2C Port: SH1.0 4-pin interface, which is compatible with QWIIC and STEMMA QT.
  • These I2C interfaces are connected to the Raspberry Pi’s I2C interface via GPIO2 (SDA) and GPIO3 (SCL).
  • Pin: I2C.
  • API: class I2C.
SPI Pin
  • P2.54 7-pin SPI interface.
  • Pin: SPI.
UART Pin
  • P2.54 4-pin interface.
  • Pin: UART.
WS2812 Port
RST Button
  • The RST button, when using Ezblock, serves as a button to restart the Ezblock program.
  • If not using Ezblock, the RST button does not have a predefined function and can be fully customized according to your needs.
  • Pin: Buttons.
  • API: class Pin
USR Button
  • The functions of USR Button can be set by your programming. (Pressing down leads to a input β€œ0”; releasing produces a input β€œ1”. )
  • API: class Pin, you can use Pin("SW") to define it.
  • Pin: Buttons.
Battery Indicator
  • Two LEDs light up when the voltage is higher than 7.6V.
  • One LED lights up in the 7.15V to 7.6V range.
  • Below 7.15V, both LEDs turn off.
  • Battery Level Indicator.
Speaker and MIC
  • Speaker: This is a 2030 audio chamber speaker.
  • Speaker Port: The Robot HAT is equipped with onboard I2S audio output, along with a 2030 audio chamber speaker, providing a mono sound output.
  • MIC: The Robot HAT is equipped with a MEMS microphone, which can be used to collect ambient sound.
  • Pin: Speaker and MIC.
  • API: class Music
Pin Mapping
Raspberry Pi IO
Robot Hat V5
Raspberry Pi
Raspberry Pi
Robot Hat V5
NC
3V3
5V
5V
SDA
SDA
5V
5V
SCL
SCL
GND
GND
DIGITAL 4
GPIO4
TXD
TXD
GND
GND
RXD
RXD
DIGITAL 17
GPIO17
GPIO18
I2S BCLK
DIGITAL 27
GPIO27
GND
GND
DIGITAL 22
GPIO22
GPIO23
CHG
NC
3V3
GPIO24
NC
SPI MOSI / WS2812 DOUT
MOSI
GND
GND
SPI MISO
MISO
GPIO25
USR BUTTON
SPI SCLK
SCLK
CE0
SPI CE0
GND
GND
CE1
NC
NC
ID_SD
ID_SC
NC
MCU Reset
GPIO5
GND
GND
(SPI)BSY
GPIO6
GPIO12
Speaker Enable
NC
GPIO13
GND
GND
I2S LRCLK
GPIO19
GPIO16
RST BUTTON
USER LED
GPIO26
GPIO20
I2S DATAIN
GND
GND
GPIO21
I2S DATAOUT
Digital IO
Robot HAT has 4 sets of P2.54 3Pin digital pins.
../_images/digitalio_v5.png
Digital IO
Robot Hat V5
Raspberry Pi
17
GPIO17
GPIO4
27
GPIO27
22
GPIO22
ADC
../_images/adcpin_v5.png
The Robot HAT features four sets of 3 Pin ADC (Analog to Digital Converter) pins, each spaced 2.54mm apart. These pins operate at a 3.3V power supply. The ADC function, offering 12-bit precision, is facilitated by an onboard microcontroller. Detailed instructions for reading ADC values are provided in the On-Board MCU section.
../_images/btradc_v5.png
Also, ADC channel A4 is connected to the battery through a voltage divider using resistors, which will be used to measure the battery voltage to estimate the approximate battery charge.
The voltage divider ratio is 200K/100K, so:
  • A4 voltage (Va4) = value_A4 / 4095.0 * 3.3
  • Battery voltage (Vbat) = Va4*3
  • Battery voltage (Vbat) = value_A4 / 4095.0 * 3.3 * 3
PWM
../_images/pwmpin_v5.png
Robot HAT has 4 sets of 3 Pin PWM pins, each spaced 2.54mm apart, and the power supply is 5V. The method of using the PWM is described in detail in On-Board MCU.
PWM13 ~ 19 channels are used for motor drive.
I2C
../_images/i2cpin_v5.png
The Robot HAT has two I2C interfaces. One is the P2.54 4-pin interface, and the other is the SH1.0 4-pin interface, which is compatible with QWIIC and STEMMA QT. These I2C interfaces are connected to the Raspberry Pi’s I2C interface via GPIO2 (SDA) and GPIO3 (SCL). The board also features an On-Board MCU, and the two signal lines have 10K pull-up resistors.
SPI
../_images/spipin_v5.png
The SPI interface of the Robot HAT is a 7-pin P2.54 interface. It connects to the SPI interface of the Raspberry Pi and includes an additional I/O pin that can be used for purposes such as interrupts or resets.
SPI
Robot Hat V5
Raspberry Pi
BSY
GPIO6
CS
CE0(GPIO8)
SCK
SCLK(GPIO11)
MI
MISO(GPIO9)
MO
MOSI(GPIO10)
3V3
3.3V Power
GND
Ground
UART
../_images/uartpin_v5.png
The UART interface of the Robot HAT is a 4-pin P2.54 interface. It connects to the Raspberry Pi’s GPIO14 (TXD) and GPIO15 (RXD) pins.
WS2812 Port
../_images/ws2812pin_v5.png
The Robot HAT comes with 1 WS2812 port (ZH1.5 3 Pin), which can be used to control 1 WS2812 LED strip.
This Pin is shared with SPI MOSI, so it can not be used as SPI MOSI at the same time.
Buttons
../_images/btn_led_v5.png
The Robot HAT comes with 1 LED and 2 buttons, all directly connected to the Raspberry Pi’s GPIO pins. The RST button, when using Ezblock, serves as a button to restart the Ezblock program. If not using Ezblock, the RST button does not have a predefined function and can be fully customized according to your needs.
LED & Button
Robot Hat V4
Raspberry Pi
LED
GPIO26
USR
GPIO25
RST
GPIO16
Speaker and MIC
../_images/speaker_v5.png
The Robot HAT is equipped with onboard I2S audio output/input, along with a 2030 audio chamber speaker, providing a mono sound output. The onboard microphone can be used to receive audio signals.
I2S
I2S
Raspberry Pi
WS
GPIO19
SCLK
GPIO18
Audio OUT (Speaker)
GPIO21
Aduio IN (MIC)
GPIO20
The speaker has a switch to control the speaker’s on/off status, which is connected to the Raspberry Pi’s GPIO 12. When the switch is turned on, the speaker will be enabled, and when the switch is turned off, the speaker will be disabled. If you do not need the speaker, you can turn off the switch to protect it.
Speaker Enable
I2S
Raspberry Pi
Switch
GPIO12
Enable
High
Disable
Low
Motor Port
The motor driver of the Robot HAT supports 4 channels and can be controlled using 8 PWM signals for direction and speed control.
Motor Driver
Motor
PWM
Motor1 A
PWM12
Motor1 B
PWM13
Motor2 A
PWM14
Motor2 B
PWM15
Motor3 A
PWM16
Motor3 B
PWM17
Motor4 A
PWM18
Motor4 B
PWM19
The motor drive mode is as follow.
Battery Level Indicator
The battery level indicator on the Robot HAT monitors the battery voltage using a voltage divider method and serves as a reference for estimating the battery level. The relationship between the LED and voltage is as follows:
Battery Level
LED Battery
Total Voltage
2 LEDs on
Greater than 7.3V
1 LED on
Greater than 6.9V
Both LEDs off
Less than 6.9V
When any one of the batteries reaches or exceeds 4.1V while the others are below that threshold, the charging current of that specific battery will be reduced.
Servo Zeroing Button
../_images/btn_servo_zeroing_v5.png
The servo zeroing button is used to calibrate the servo’s zero position. When you press the button twice, all the PWM signals will be set to 1500us pulse, 20000us period. That is, the servo will be in the middle position. You should secure the servo arm to the servo in this state.
Press the button twice again, all the PWM signals will be set to 0 pulse.
