Dazzling LightΒΆ
In the previous project, we learned to use some simple functions to make RGB Matrix Shield work. So here, we will use the draw_line() function with different colors to make RGB Matrix HAT make more cool effects.
We have written two light blinking modes, dazzling_light() and dazzling_light()2 for reference.
When the program is running, you will first see the RGB matrix shield flowing on displaying different colors. After a while, you will notice that the flow of light becomes more smooth.
How it works?
for (int i=0; i<50; i++){
dazzling_light();
for (int i=0; i<5; i++){
dazzling_light2();
The main logic is to call the dazzling_light() function 50 times and then call the dazzling_light2() function 5 times.
byte line[8][4] = {{0, 0, 0, 7},
{1, 0, 1, 7},
{2, 0, 2, 7},
{3, 0, 3, 7},
{4, 0, 4, 7},
{5, 0, 5, 7},
{6, 0, 6, 7},
{7, 0, 7, 7}};
Define a two-dimensional array line[8][4] to store the starting and ending coordinates of the 8 vertical lines.
byte color[7][3] = {{255,0,0},
{255,102,0},
{255,255,0},
{0,255,0},
{0,128,128},
{0,0,255},
{128,0,128}};
Define a two-dimensional array color[7][3] to store the 7 colors, red, orange, yellow, green, blue, blue and purple.
int i = 0;
void dazzling_light(){
for (int j=0; j<8; j++){
draw_line(line[j],color[i][0],color[i][1],color[i][2]);
i++;
if (i == 6){
i = 0;
image();
The dazzling_light() function is to write different colors (red, orange, yellow, green, blue, blue and purple) to the 8 vertical lines, where the first and last lines are red.
The for loop traverses the array line[] and draws eight vertical lines on the RGB matrix shield with draw_line(). The colors are chosen from the array color[7][3], for example, color[0] represents the first element {255, 0, 0}, while color[0][1] represents 255.
void dazzling_light2(){
for (long firstPixelHue = 0; firstPixelHue < 65536; firstPixelHue += 500) {
long pixelHue = firstPixelHue + (j * 65536L / 16);
draw_line(line[j], gamma32(ColorHSV(pixelHue)));
image();
When you call the dazzling_light2() function, you will notice a softer flow of colors. This is because we have split the colors into more colors, making the transition between colors more smooth.
Two for loops are defined in dazzling_light2(). The inner loop is to fill the eight vertical lines with eight colors, and the outer loop is to add a value to each color to switch to the next color to achieve the effect of color flow.
Here ColorHSV() and gamma32() are functions packaged in the library. The former is used to handle decimal numbers, which is equivalent to mapping all the colors of the RGB matrix shield to the range 0 to 65536. gamma32() is used for transcoding, converting the return value of ColorHSV() into an acceptable argument to draw_line().
