šŸ‘‰ Ready to explore and create with us? Click [here] and join today!
DIY RasPad Monitor Device
Description
You can turn RasPad3 into a game screen playing with your friends, a smart alarm showing the weather and time, a display monitoring your robot’s action and many other things.
This article will show you how to DIY a RasPad Monitor Device on your RasPad 3. Let’s take a look!
_images/pir0.jpg
Required Components
  • A RasPad 3
  • 8G+ SD Card
  • Scratch 3 (eitherĀ onlineĀ orĀ offline)
  • Micro SD Card Reader
  • 40P Ribbon Cable
  • T-Type GPIO Extension Board
  • Breadboard
  • PIR Module
  • Camera Module
  • FFC Cable
  • Jump Wire F/M
You Will Learn
  • Use Raspberry Pi extensions on Scratch.
  • Use audio functions on Scratch.
  • Use PIR module.
Lesson Guide
Build the Circuit
First connect the GPIO Extension Board, please read GPIO Extension Board for specific steps.
_images/pir2.jpg
Plug the T-type GPIO extension board into the breadboard and build the circuit.
_images/pir4.png
For the camera installation tutorial, please refer to Assemble the Camera Module.
_images/banana1.jpg
Programming with Scratch 3
In this step you will learn how to upload the prepared music to the Scratch. Tap the ā€œSoundsā€option on the left upper corner,then tap the ā€œspeakerā€ icon and choose ā€œUpload Soundā€ icon to upload the prepared music file - hello, finally tapā€œOpenā€ to confirm.
_images/pir9.jpg
Tap Add icon at lower left corner and chooseā€œVideo Sensingā€andā€œRaspberry Pi GPIOā€to add two functions.
_images/pir10.jpg
Back to the main page, drag a ā€œwhen gpio 0 is highā€ from Raspberry Pi GPIO function and a ā€œplay sound (hello) until doneā€to the coding area.
_images/pir11.png
Stick the pir module and camera to the wall outside the door, And stick the RasPad to the wall inside the door or anywhere. When the door is opened, you will hear music and then see who is there.
_images/pir1.jpg
If you hate reading, see this video.
In this article, we introduce how to use RasPad 3 to DIY a RasPad Monitor Device. Surely, you can also add a relay and a stepper motor to open the door when someone is detected at the door.
