πŸ‘‰ Ready to explore and create with us? Click [here] and join today!
2.2.4 Reed Switch Module
Introduction
In this project, we will learn about the reed switch, which is an electrical switch that operates by means of an applied magnetic field.
../_images/2.2.4reed_switch.png
Required Components
../_images/2.2.4component.png
ITEMS IN THIS KIT
COMPONENT INTRODUCTION
PURCHASE LINK
GPIO Extension Board
Jumper Wires
Resistor
LED
Reed Switch Module
Schematic Diagram
T-Board Name
physical
wiringPi
GPIO17
Pin 11
0
17
GPIO27
Pin 13
GPIO22
Pin 15
../_images/reed_schematic.png ../_images/reed_schematic2.png
Experimental Procedures
Step 1: Build the circuit.
../_images/2.2.4fritzing.png
Step 2: Change directory.
cd ~/raphael-kit/c/2.2.4/
Step 3: Compile.
gcc 2.2.4_ReedSwitch.c -lwiringPi
Step 4: Run.
The green LED will light up when the code is run. If a magnet is placed close to the reed switch module, the red LED lights up; take away the magnet and the green LED lights up again.
#include <wiringPi.h>
#include <stdio.h>
#define ReedPin             0
#define Gpin                2
#define Rpin                3
void LED(char* color)
    pinMode(Gpin, OUTPUT);
    pinMode(Rpin, OUTPUT);
    if (color == "RED")
        digitalWrite(Rpin, HIGH);
        digitalWrite(Gpin, LOW);
    else if (color == "GREEN")
        digitalWrite(Rpin, LOW);
        digitalWrite(Gpin, HIGH);
    else
        printf("LED Error");
int main(void)
    pinMode(ReedPin, INPUT);
    LED("GREEN");
        if(0 == digitalRead(ReedPin)){
            delay(10);
                LED("RED");
                printf("Detected Magnetic Material!\n");
        else if(1 == digitalRead(ReedPin)){
            delay(10);
                while(!digitalRead(ReedPin));
                LED("GREEN");
Code Explanation
#define ReedPin             0
#define Gpin                2
#define Rpin                3
Pin GPIO17, GPIO27 and GPIO22 of the T_Extension Board is corresponding to the GPIO0, GPIO2 and GPIO3 in wiringPi. Assign GPIO0, GPIO2 and GPIO3 to ReedPin, Gpin and Rpin.
    if (color == "RED")
    else
Set a LED() function to control the 2 LEDs, the parameter of this function is color.
When color is "RED", set Rpin to HIGH (light up the red LED) and Gpin to LOW (turn off the green LED); when color is "GREEN", then light up the green LED and turn off the red LED.
            delay(10);
                LED("RED");
            delay(10);
                LED("GREEN");
Read the value of the reed switch module, if the value read 2 times is 0, call LED("RED") to light up the red LED and print "Magnetic material detected!".
If the value is 1, the green LED is lit.
Phenomenon Picture
../_images/2.2.4reed_switch.JPG
