Introduction to Pico RDP¶
The Pico Robotics Development Platform (RDP) is a Wi-Fi extension module for the Raspberry Pi Pico designed by SunFounder.
It integrates industry-leading Wi-Fi solutions, rich peripheral interfaces, and supports multiple compilers for development.
It also has IO expansion interface circuitry, LED power indicator circuitry, voltage measurement circuitry, and an on-board 4-channel DC motor driver circuit.
When you use Pico RDP for development and debugging, you can connect peripherals as needed, and the rich external interfaces can make your projects more interesting.
Features
Microcontroller: Raspberry Pi Pico module
Wi-Fi: ESP8266 Wi-Fi module, 802.11 b/g/n (802.11n, speeds up to 150 Mbps), 2.4 GHz ~ 2.5 GHz frequency range
RUN button: reset button
Input voltage: 7.0-30.0V (PH2.0-2P)
Output voltage: 7.0-30.0V (PH2.0-2P), 5.0V, 3.3V
Output current: 5V/5A, 3.3V/1A
One channel SH1.0-4P port: I2C port.
Four channel XH2.54-4P port: DC motor port
12 x PWM channel, 3 x ADC channel, 4 x GPIO pins.
One channel SH1.0-4P port: I2C port. Compatible with QwIIC and STEMMA QT
Pico RDP’s Pins
Here is the schematic of the Pico RDP: PDF Pico RDP Schematic.
