6.3 Read from the MPU-6050
In this lesson, we’ll explore how to interface the MPU-6050 6-axis motion tracking sensor with the Raspberry Pi Pico 2 W. The MPU-6050 combines a 3-axis gyroscope and a 3-axis accelerometer, providing raw sensor data over the I2C communication protocol.
PURCHASE LINK |
Pico 2 W Starter Kit |
450+ |
SN |
COMPONENT INTRODUCTION |
QUANTITY |
PURCHASE LINK |
Micro USB Cable |
Several |
Understanding the MPU-6050 Sensor
The MPU-6050 sensor is widely used in projects that require motion tracking and orientation detection, such as drones, robotics, and gaming devices.
Accelerometer: Measures acceleration forces along the X, Y, and Z axes. This includes gravitational acceleration, allowing you to determine the tilt or orientation of the sensor.
Gyroscope: Measures rotational velocity around the X, Y, and Z axes, providing information about how fast the sensor is spinning.
Schematic
Writing the Code
We’ll write a program that initializes the MPU-6050 sensor, reads acceleration and gyroscope data, and prints the values to the Serial Monitor.
You can open the file
6.3_6axis_motion_tracking.inounder the path ofpico-2w-kit-main/arduino/6.3_6axis_motion_tracking.Or copy this code into Arduino IDE.
Then select the Raspberry Pi Pico board and the correct port before clicking the Upload button.
The
Adafruit MPU6050library is used here, you can install it from the Library Manager.
#include <Adafruit_MPU6050.h>
#include <Wire.h>
// Create an MPU6050 object
Adafruit_MPU6050 mpu;
void setup(void) {
// Initialize Serial Communication
Serial.begin(115200);
Serial.println("Adafruit MPU6050 test!");
// Try to initialize the MPU6050
if (!mpu.begin()) {
Serial.println("Failed to find MPU6050 chip");
while (1) {
delay(10);
Serial.println("MPU6050 Found!");
// Set accelerometer range
mpu.setAccelerometerRange(MPU6050_RANGE_8_G);
Serial.print("Accelerometer range set to: ");
switch (mpu.getAccelerometerRange()) {
case MPU6050_RANGE_2_G:
Serial.println("+-2G");
break;
case MPU6050_RANGE_4_G:
Serial.println("+-4G");
break;
case MPU6050_RANGE_8_G:
Serial.println("+-8G");
break;
case MPU6050_RANGE_16_G:
Serial.println("+-16G");
break;
// Set gyroscope range
mpu.setGyroRange(MPU6050_RANGE_500_DEG);
Serial.print("Gyro range set to: ");
switch (mpu.getGyroRange()) {
case MPU6050_RANGE_250_DEG:
Serial.println("+-250 deg/s");
break;
case MPU6050_RANGE_500_DEG:
Serial.println("+-500 deg/s");
break;
case MPU6050_RANGE_1000_DEG:
Serial.println("+-1000 deg/s");
break;
case MPU6050_RANGE_2000_DEG:
Serial.println("+-2000 deg/s");
break;
// Set filter bandwidth
mpu.setFilterBandwidth(MPU6050_BAND_21_HZ);
Serial.print("Filter bandwidth set to: ");
switch (mpu.getFilterBandwidth()) {
case MPU6050_BAND_260_HZ:
Serial.println("260 Hz");
break;
case MPU6050_BAND_184_HZ:
Serial.println("184 Hz");
break;
case MPU6050_BAND_94_HZ:
Serial.println("94 Hz");
break;
case MPU6050_BAND_44_HZ:
Serial.println("44 Hz");
break;
case MPU6050_BAND_21_HZ:
Serial.println("21 Hz");
break;
case MPU6050_BAND_10_HZ:
Serial.println("10 Hz");
break;
case MPU6050_BAND_5_HZ:
Serial.println("5 Hz");
break;
Serial.println("");
delay(100);
// Get new sensor events with the readings
sensors_event_t a, g, temp;
mpu.getEvent(&a, &g, &temp);
// Print acceleration values
Serial.print("Acceleration X: ");
Serial.print(a.acceleration.x);
Serial.print(" m/s^2, Y: ");
Serial.print(a.acceleration.y);
Serial.print(" m/s^2, Z: ");
Serial.print(a.acceleration.z);
Serial.println(" m/s^2");
// Print gyroscope values
Serial.print("Rotation X: ");
Serial.print(g.gyro.x);
Serial.print(" rad/s, Y: ");
Serial.print(g.gyro.y);
Serial.print(" rad/s, Z: ");
Serial.print(g.gyro.z);
Serial.println(" rad/s");
delay(500); // Adjust delay as needed
After uploading the code, the Serial Monitor should display the acceleration and rotation values continuously.
MPU6050 Found!
Accelerometer range set to: +-8G
Gyro range set to: +-500 deg/s
Filter bandwidth set to: 21 Hz
Acceleration X: 0.00 m/s^2, Y: 0.00 m/s^2, Z: 9.81 m/s^2
Rotation X: 0.02 rad/s, Y: -0.01 rad/s, Z: 0.00 rad/s
Acceleration X: 0.10 m/s^2, Y: 0.05 m/s^2, Z: 9.76 m/s^2
Rotation X: 0.15 rad/s, Y: -0.05 rad/s, Z: 0.02 rad/s
Gently rotate or move the MPU-6050 sensor module. Observe changes in the acceleration and rotation values corresponding to the movement.
Understanding the Code
Including Libraries and Defining Constants:
Adafruit_MPU6050.h: Includes the MPU6050 library for easier interfacing.Wire.h: Includes the I2C communication library.mpu: Creates an MPU6050 object to interact with the sensor.
Setup Function:
MPU6050 Initialization:
Attempts to initialize the MPU6050 sensor. If unsuccessful, it prints an error message and halts the program.
Serial.println("Adafruit MPU6050 test!"); // Try to initialize the MPU6050 if (!mpu.begin()) { Serial.println("Failed to find MPU6050 chip"); while (1) { delay(10); } } Serial.println("MPU6050 Found!");
Accelerometer Range:
Sets the accelerometer range to ±8G and prints the current range.
mpu.setAccelerometerRange(MPU6050_RANGE_8_G); Serial.print("Accelerometer range set to: "); switch (mpu.getAccelerometerRange()) { case MPU6050_RANGE_2_G: Serial.println("+-2G"); break; ... case MPU6050_RANGE_16_G: Serial.println("+-16G"); break; }
Gyroscope Range:
Sets the gyroscope range to ±500 degrees per second and prints the current range.
mpu.setGyroRange(MPU6050_RANGE_500_DEG); Serial.print("Gyro range set to: "); switch (mpu.getGyroRange()) { case MPU6050_RANGE_250_DEG: Serial.println("+-250 deg/s"); break; ... case MPU6050_RANGE_2000_DEG: Serial.println("+-2000 deg/s"); break; }
Setting Filter Bandwidth:
Configures the filter bandwidth to 21 Hz to reduce noise and prints the current setting.
mpu.setFilterBandwidth(MPU6050_BAND_21_HZ); Serial.print("Filter bandwidth set to: "); switch (mpu.getFilterBandwidth()) { case MPU6050_BAND_260_HZ: Serial.println("260 Hz"); break; ... case MPU6050_BAND_5_HZ: Serial.println("5 Hz"); break; }
Loop Function:
Reading Sensor Data:
sensors_event_t a, g, temp;: Creates event objects to store accelerometer, gyroscope, and temperature data.mpu.getEvent(&a, &g, &temp);: Retrieves the latest sensor data.
sensors_event_t a, g, temp; mpu.getEvent(&a, &g, &temp);
Printing Sensor Data:
Acceleration: Prints acceleration values along the X, Y, and Z axes in meters per second squared (m/s²).
Rotation: Prints gyroscope values (rotational velocity) around the X, Y, and Z axes in radians per second (rad/s).
// Print acceleration values Serial.print("Acceleration X: "); Serial.print(a.acceleration.x); ... Serial.print(g.gyro.y); Serial.print(" rad/s, Z: "); Serial.print(g.gyro.z); Serial.println(" rad/s");
Troubleshooting
No Readings Displayed:
Check all wiring connections, especially the I2C lines (SCL and SDA).
Ensure the MPU-6050 sensor is receiving power (VCC and GND connections).
Verify that the correct GPIO pins are defined in the code.
Incorrect Readings:
Ensure that the MPU-6050 sensor is properly seated in the breadboard.
Verify that the sensor’s range and filter settings match the desired application.
Check for any loose connections or shorts in the wiring.
Sensor Interference:
Avoid placing the sensor near other electronic devices that might cause interference.
Ensure there are no physical obstructions blocking the sensor’s movement.
Further Exploration
Combining with Other Sensors:
Integrate the MPU-6050 with GPS modules, magnetometers, or other sensors to create comprehensive tracking systems.
Building a Motion-Based Game Controller:
Use the MPU-6050 to detect movement and orientation, allowing for the creation of motion-controlled gaming devices.
Creating a Self-Balancing Robot:
Utilize the accelerometer and gyroscope data to maintain balance and stability in robotic applications.
Implementing Sensor Fusion Algorithms:
Combine accelerometer and gyroscope data to calculate orientation angles using algorithms like the Kalman filter or complementary filter.
Conclusion
In this lesson, you’ve learned how to interface the MPU-6050 6-axis motion tracking sensor with the Raspberry Pi Pico. By leveraging the Adafruit MPU6050 library, you can easily retrieve and interpret accelerometer and gyroscope data, enabling a wide range of motion and orientation-based applications. The optional LED indicator adds a simple way to provide visual feedback based on sensor readings, enhancing the interactivity of your projects.
