备注
Install OpenSSH via PowerShell
If you see the following error when running ssh <username>@<hostname>.local or ssh <username>@<IP>:
ssh: The term 'ssh' is not recognized as the name of a cmdlet, function, script file, or operable program.
It means your Windows system does not have OpenSSH installed. Follow the steps below to install it manually.
Open the Windows Start Menu, type powershell, right-click Windows PowerShell, and select Run as administrator.
Install the OpenSSH Client:
After installation, you should see output similar to:
Path : Online : True RestartNeeded : False
Verify the installation:
If OpenSSH is installed, the output will include:
Name : OpenSSH.Client~~~~0.0.1.0 State : Installed Name : OpenSSH.Server~~~~0.0.1.0 State : NotPresent
警告
If
Installeddoes not appear, your Windows system may be too old. In this case, we recommend using a third-party SSH tool. See: PuTTYClose PowerShell, reopen it (no need to run as administrator this time), and use the
sshcommand to log in:ssh <username>@<hostname>.local
