3-pin Battery
VCC: Battery positive terminal, here there are two sets of VCC and GND is to increase the current and reduce the resistance.
Middle: To balance the voltage between the two cells and thus protect the battery.
GND: Negative battery terminal.
This is a custom battery pack made by SunFounder consisting of two 18650 batteries with a capacity of 2000mAh. The connector is XH2.54 3P, which can be charged directly after being inserted into the Robot HAT.
Features
Composition: Li-ion
Battery Capacity: 2000mAh, 14.8Wh
Battery Weight: 90.8g
Number of Cells: 2
Connector: XH2.54 3P
Over-discharge protection: 6.0V
5-pin Battery
This is a custom battery pack made by SunFounder consisting of two 18650 batteries with a capacity of 2000mAh. The connector is PH2.0-5P, which can be charged directly after being inserted into the shield.
Features
Composition: Li-ion
Number of Cells: 2
Connector: PH2.0-5P
