Record Video¶
This example allows us to record a video.
Here you will use two windows at the same time:
One is Terminal, you can type wasd here to control the orientation of the camera, type q to record/pause/continue recording, type e to stop recording, and type g to exit shooting . If the program has not been terminated after exiting the shooting, please type ctrl+c.
Another browser interface, after the program runs, you will need to enter http://<Your Raspberry Pi IP>:9000/mjpg in the PC browser (such as chrome) to view the viewfinder screen.
Run the Code
cd /home/pi/pan-tilt-hat/examples
sudo python3 record_video.py
View the Image
After the code runs, the terminal will display the following prompt:
No desktop !
* Environment: production
* Debug mode: off
Then you can enter http://<your IP>:9000/mjpg in the browser to view the video screen. such as: http://192.168.18.113:9000/mjpg
from time import sleep,strftime,localtime
from vilib import Vilib
import sys
sys.path.append('./')
from servo import Servo
import tty
import termios
def readchar():
fd = sys.stdin.fileno()
old_settings = termios.tcgetattr(fd)
tty.setraw(sys.stdin.fileno())
ch = sys.stdin.read(1)
finally:
termios.tcsetattr(fd, termios.TCSADRAIN, old_settings)
return ch
manual = '''
Press keys on keyboard to record value!
W: up
A: left
S: right
D: down
Q: record/pause/continue
E: stop
G: Quit
# region init
pan = Servo(pin=13, min_angle=-90, max_angle=90) # pan_servo_pin (BCM)
tilt = Servo(pin=12, min_angle=-90, max_angle=30) # be careful to limit the angle of the steering gear
panAngle = 0
tiltAngle = 0
pan.set_angle(panAngle)
tilt.set_angle(tiltAngle)
Vilib.rec_video_set["path"] = "/home/pi/Videos/vilib/" # set path
vname = None
rec_flag = 'stop' # start,pause,stop
#endregion init
# rec control
def rec_control(key):
global rec_flag, vname
# start,pause
if key == 'q':
key = None
if rec_flag == 'stop':
rec_flag = 'start'
# set name
vname = strftime("%Y-%m-%d-%H.%M.%S", localtime())
Vilib.rec_video_set["name"] = vname
# start record
Vilib.rec_video_run()
Vilib.rec_video_start()
print('rec start ...')
elif rec_flag == 'start':
rec_flag = 'pause'
Vilib.rec_video_pause()
print('pause')
elif rec_flag == 'pause':
rec_flag = 'start'
print('continue')
# stop
elif key == 'e' and rec_flag != 'stop':
key = None
rec_flag = 'stop'
Vilib.rec_video_stop()
print("The video saved as %s%s.avi"%(Vilib.rec_video_set["path"],vname),end='\n')
# region servo control
def limit(x,min,max):
if x > max:
return max
elif x < min:
return min
return x
def servo_control(key):
global panAngle,tiltAngle
if key == 'w':
tiltAngle -= 1
tiltAngle = limit(tiltAngle, -90, 30)
if key == 's':
tiltAngle += 1
if key == 'a':
panAngle += 1
panAngle = limit(panAngle, -90, 90)
if key == 'd':
panAngle -= 1
# endregion servo control
def main():
Vilib.camera_start(vflip=True,hflip=True)
sleep(2)
print(manual)
key = readchar().lower()
# rec control
rec_control(key)
# servo control
servo_control(key)
# esc
if key == 'g':
Vilib.camera_close()
break
sleep(0.1)
if __name__ == "__main__":
main()
How it works?
This article can be divided into three parts to analyze:
Keyboard input
Servo control
Record video
The first two parts are consistent with Continuous Shooting. The record video function code is as follows:
# region init
vname = None
# endregion init
# rec control
# start,pause
if key == 'q':
key = None
rec_flag = 'start'
# set name
# start record
rec_flag = 'pause'
print('pause')
rec_flag = 'start'
print('continue')
# stop
key = None
rec_flag = 'stop'
def main():
# rec control
rec_control(key)
# servo control
# esc
if key == 'g':
break
main()
Parameters related to recording include the following:
Vilib.rec_video_set["path"]:The address where the video is savedVilib.rec_video_set["name"]:The name of the saved video
Functions related to recording include the following:
Vilib.rec_video_run():Start recordingVilib.rec_video_pause():Pause recordingVilib.rec_video_start():Continue recordingVilib.rec_video_stop():Stop recording
