Color Detection¶
Say a color and mark it in the field of view. This is not difficult for most humans, because we have been trained in this way since we were young.
For computers, thanks to deep learning, such tasks can also be accomplished. In this project, there is an algorithm that can find a certain color (6 kinds in total), such as finding “orange”.
Run the Code
cd /home/pi/pan-tilt-hat/examples
sudo python3 color_detection.py
View the Image
After the code runs, the terminal will display the following prompt:
No desktop !
* Environment: production
* Debug mode: off
Then you can enter http://<your IP>:9000/mjpg in the browser to view the video screen. such as: https://192.168.18.113:9000/mjpg
Call the Function
After the program runs, you will see the following information in the final:
Input key to call the function!
1: Color detect : red
2: Color detect : orange
3: Color detect : yellow
4: Color detect : green
5: Color detect : blue
6: Color detect : purple
0: Switch off Color detect
S: Display detected object information
Q: Photo shoot
G: Quitn
Please follow the prompts to activate the corresponding functions.
Color Detect
Entering a number between
1~6will detect one of the colors in “red, orange, yellow, green, blue, purple”. Enter0to turn off color detection.![]()
You can download and print the
PDF Color Cardsfor color detection.Display Information
Entering
swill print the information of the color detection target in the terminal. Including the center coordinates (X, Y) and size (Weight, height) of the measured object.
from vilib import Vilib
color_flag = 'close'
color_list = ['close', 'red','orange','yellow','green','blue','purple']
manual = '''
Q: Photo shoot
G: Quit
def color_detect(color):
if color == 'close':
print("Color detect off!")
Vilib.color_detect_switch(False)
print("detecting color :" + color)
Vilib.color_detect(color)
def show_info():
if color_flag == 'close':
print("Color detection is turned off !")
if Vilib.detect_obj_parameter['color_n']!=0:
color_coodinate = (Vilib.detect_obj_parameter['color_x'],Vilib.detect_obj_parameter['color_y'])
color_size = (Vilib.detect_obj_parameter['color_w'],Vilib.detect_obj_parameter['color_h'])
print("Coordinate:",color_coodinate,"Size",color_size)
print("No %s detected!"%color_flag)
def main():
global color_flag
path = "/home/pi/Pictures/vilib/color_detection/"
Vilib.camera_start(vflip=True,hflip=True)
time.sleep(2)
print(manual)
key = input().lower()
if key in ['0', '1', '2', '3', '4', '5', '6']:
color_flag = color_list[int(key)]
color_detect(color_flag)
elif key == "s":
show_info()
elif key == 'q':
_time = time.strftime("%y-%m-%d_%H-%M-%S", time.localtime())
Vilib.take_photo(photo_name=str(_time),path=path)
print("The photo save as %s%s.jpg"%(path,_time))
elif key == "g" :
Vilib.camera_close()
break
break
if __name__ == "__main__":
main()
How it works?
The first thing you need to pay attention to here is the following function. These two functions allow you to start the camera.
Functions related to “color detection”:
Vilib.color_detect(color): For color detection, only one color detection can be performed at the same time. The parameters that can be input are:"red","orange","yellow","green","blue","purple"Vilib.color_detect_switch(False): Switch OFF color detection
The information detected by the target will be stored in the detect_obj_parameter = Manager().dict() dictionary.
In the main program, you can use it like this:
The keys of the dictionary and their uses are shown in the following list:
color_x: the x value of the center coordinate of the detected color block, the range is 0~320.color_y: the y value of the center coordinate of the detected color block, the range is 0~240.color_w: the width of the detected color block, the range is 0~320.color_h: the height of the detected color block, the range is 0~240.color_n: the number of detected color patches.
