Panorama¶
A panorama is a wide-angle view or representation of the physical space, which is composed of multiple standard photos stitched together to bring a visual wonder with a field of view far beyond the human eye.
In this article, you will use the slow rotation of the pan-tilt to obtain multiple photos to combine a long panorama picture.
Run the Code
cd /home/pi/pan-tilt-hat/examples
sudo python3 panorama.py
View the Image
After the code runs, the terminal will display the following prompt:
No desktop !
* Environment: production
* Debug mode: off
Then you can enter http://<your IP>:9000/mjpg in the browser to view the video screen. such as: http://192.168.18.113:9000/mjpg
from time import sleep,strftime,localtime
from vilib import Vilib
import sys
sys.path.append('./')
from servo import Servo
import cv2
import os
import tty
import termios
# region read keyboard
def readchar():
fd = sys.stdin.fileno()
old_settings = termios.tcgetattr(fd)
tty.setraw(sys.stdin.fileno())
ch = sys.stdin.read(1)
finally:
termios.tcsetattr(fd, termios.TCSADRAIN, old_settings)
return ch
manual = '''
Press keys on keyboard to record value!
Q: take panoramic photo
G: Quit
# endregion
# # check dir
def check_dir(dir):
if not os.path.exists(dir):
os.makedirs(dir)
except Exception as e:
print(e)
# region init
pan = Servo(pin=13, min_angle=-90, max_angle=90) # pan_servo_pin (BCM)
tilt = Servo(pin=12, min_angle=-90, max_angle=30) # be careful to limit the angle of the steering gear
panAngle = 0
tiltAngle = 0
pan.set_angle(panAngle)
tilt.set_angle(tiltAngle)
# endregion
Status_info = {
0: 'OK',
1: 'ERR_NEED_MORE_IMGS',
2: 'ERR_HOMOGRAPHY_EST_FAIL',
3: 'ERR_CAMERA_PARAMS_ADJUST_FAIL',
def panorama_shooting(path):
global panAngle,tiltAngle
temp_path = "/home/pi/Pictures/vilib/panorama/.temp/"
imgs =[]
# check path
check_dir(path)
check_dir(temp_path)
# take photo
for a in range(panAngle,-81,-5):
panAngle = a
sleep(0.1)
num = 0
for angle in range(-80,81,20):
for a in range(panAngle,angle,1):
panAngle = a
pan.set_angle(a)
sleep(0.1)
sleep(0.5)
# sleep(0.5)
print(num,angle)
Vilib.take_photo(photo_name='%s'%num,path=temp_path)
sleep(0.2)
num += 1
# stitch image
stitcher = cv2.Stitcher_create(cv2.Stitcher_SCANS)
for index in range(num):
imgs.append(cv2.imread('%s/%s.jpg'%(temp_path,index)))
print('imgs num: %s, '%len(imgs))
status,pano = stitcher.stitch(imgs)
# imwrite and imshow
print('status: %s , %s'%(status,Status_info[status]))
if status == 0:
cv2.imwrite('%s/%s.jpg'%(path,strftime("%Y-%m-%d-%H.%M.%S", localtime())),pano)
cv2.imshow('panorama',pano)
# remove cache
os.system('sudo rm -r %s'%temp_path)
# main
def main():
path = "/home/pi/Pictures/vilib/panorama"
Vilib.camera_start(vflip=True,hflip=True)
sleep(2)
print(manual)
key = readchar()
# take photo
if key == 'q':
print("panorama shooting ...")
# esc
if key == 'g':
print('Quit')
Vilib.camera_close()
break
sleep(0.01)
if __name__ == "__main__":
main()
How it works?
The core functions of this example are placed in the panorama_shooting(path) function. This function includes the following parts:
Path management: that is,
checkdir().Photograph:
# take photo for a in range(panAngle,-81,-5): panAngle = a pan.set_angle(panAngle) sleep(0.1) num = 0 for angle in range(-80,81,20): for a in range(panAngle,angle,1): panAngle = a pan.set_angle(a) sleep(0.1) sleep(0.5) # sleep(0.5) print(num,angle) Vilib.take_photo(photo_name='%s'%num,path=temp_path) sleep(0.2) num += 1
Here, the two functions of taking pictures and steering gear control are put together. The pan servo starts to deflection slowly counterclockwise from the -80° position, and takes a picture every 20° deflection, until the 80° position ends. After execution, you will get 9 temporary photos, which are stored in the path
temp_path.Stitching photos:
# stitch image stitcher = cv2.Stitcher_create(cv2.Stitcher_SCANS) for index in range(num): imgs.append(cv2.imread('%s/%s.jpg'%(temp_path,index))) print('imgs num: %s'%len(imgs)) status,pano = stitcher.stitch(imgs) # imwrite and imshow print('status: %s , %s'%(status,Status_info[status])) if status == 0: cv2.imwrite('%s/%s.jpg'%(path,strftime("%Y-%m-%d-%H.%M.%S", localtime())),pano) cv2.imshow('panorama',pano) os.system('sudo rm -r %s'%temp_path)
These photos are added to an array
imgs, and then call OpenCV’s Stitcher module (iestatus,pano = stitcher.stitch(imgs)) to merge them into a panoramapano. Finally, usecv2.imwrite()to writepanointo the storage space, and delete the temporary photos and their paths.For more details, please see Stitcher-Docs and Image file reading and writing-OpenCV.
