Update Firmwareď
Your device may not have the latest firmware due to ongoing product improvements. We recommend updating the firmware before your first use to ensure everything works smoothly. Updating the firmware ensures:
Bug fixes: Resolves known issues and improves stability.
App compatibility: The latest firmware is required for the RoboPilot app and Mammoth Coding to work correctly.
New features: Firmware updates may add new capabilities and improvements.
Better performance: Optimizations for WiFi connectivity, camera streaming, and motor control.
If you prefer not to update the firmware and want to keep using your current configuration, you can refer to the GalaxyRVR v1 Documentation.
1. Updating the UNO R3 Firmwareď
The R3 board carries the firmware that talks to the RoboPilot app and Mammoth Coding. Reinstall it with the web-based flasher: open GalaxyRVR Firmware Flasher in Chrome or Edge on a computer â it runs in your browser, needs no extra software, and shows each step with its own picture.
The flasher has three steps:
Connect â Turn on the rover, connect the main board to your computer with a USB A to B cable (not the Type-C one), then set the mode switch to the Upload position. Then click Next.
Flash â Click Connect & Flash. In the port window that pops up, pick your boardâs port (for example
USB Serial (COMxx)), then click Connect and the flashing starts. If it fails, simply click Connect & Flash again.
Debug â When the flash finishes you will see the following in the log window, which confirms the firmware was written and shows the current version (2.0.2). Ignore
Initialzing...and everything after it at this point: the rover is still in Upload mode, so it cannot communicate with the ESP32 CAM yet. Then click Next.Reading firmwares/galaxy-rvr-2.0.2.hex Resetting the board... Connecting to the board... Firmware written. Verified - flash matches the file. ---------- serial open at 115200 ---------- GalaxyRVR version 2.0.2 Initialzing... SET+RESET ...SET+RESET ...SET+RESET ...[FAIL]
Now follow the prompt: Turn the power switch on, set the mode switch back to its original position and press the Reset button on the R3 board.
The log window then shows the current ESP32 CAM firmware.
If the ESP32 CAM firmware is 1.5.0 or higher, the log shows the UNO R3 firmware, the ESP32 CAM firmware and finally a web address like
http://xxx.xxx.xx.xxx:9000/mjpg.If it is lower than 1.5.0, the log window shows that the ESP32 CAM firmware needs updating â continue with 2. Updating the ESP32 CAM Firmware.
2. Updating the ESP32 CAM Firmwareď
The ESP32 CAM broadcasts the Wi-Fi hotspot and captures video for the GalaxyRVR. If the firmware is outdated, these functions may not work properly. Follow the steps below to update the firmware.
Turn on the GalaxyRVRâs power switch. To start the ESP32 CAM, switch the mode to Run and press the Reset button on the R3 board.
Download the firmware file.
Extract the downloaded ZIP file. Locate the firmware file named
ai-camera-firware.ino.x.x.x.binand transfer it to your mobile device. You can use any file manager app, such as ES File Explorer or a file transfer utility.
Connect your mobile device to the GalaxyRVRâs WiFi network.
The network name (SSID) is
GalaxyRVRand the password is12345678.If you see a warning stating âNo Internet access,â please choose the option to âStay connected.â
Open a web browser on your mobile device and navigate to
http://192.168.4.1to access the ESP32 CAM OTA update page.
On this page, you will see OTA upgrade options in one of two interfaces. Version A (the former) and Version B (the latter) will appear depending on your firmware version. Simply select the corresponding upgrade steps based on the interface you see.
Version A
On the OTA page, select the firmware file and start the update:
Choose the previously downloaded
ai-camera-firmware-vX.X.X-ota.binfile from your device and click Add.Click the Update button to begin the firmware update, then wait for it to complete.
After the update is complete, the GalaxyRVRâs WiFi hotspot name will change to âAI Camera-xxxxxxâ, and the password will remain â12345678â.
Version B
On the OTA page, check the current firmware version displayed on the webpage.
If your version number is 1.5.0 or higher, an update is not required. You can skip the remaining steps and proceed directly to Quick Play.
If the version is lower than 1.5.0, please continue with the update.
Tap Upgrade Firmware, select the firmware file, and wait for the update to complete:
Tap the Upgrade Firmware button, then select the previously downloaded
ai-camera-firware.ino.x.x.x.binfile from your device.The update will begin immediately and typically takes 1-2 minutes. Once finished, select CONFIRM to restart the GalaxyRVR.
3. Verifying the Startupď
Before using the GalaxyRVR for the first time, fully charge the battery with the supplied Type-C USB cable.
Turn the power switch on.
Switch the mode to Run and press the Reset button on the R3 board.
The bottom light strip will flash green, indicating a successful startup.
