Some project code fails to compile?
Q1: 'ledcAttach' was not declared in this scope
When using LEDs, RGB LEDs, or passive buzzers, you will need the ESP32 board’s LEDC peripheral to generate PWM signals. However, the ESP32 board was recently upgraded to version 3.0, which caused changes in the function names and usage within the LEDC peripheral.
Therefore, we have updated our code accordingly. If you encounter ledc-related issues during compilation, please upgrade your ESP32 board to version 3.0 or higher.
../_images/version_3.0.3.png
Q3: “Wrong boot mode detected (0x13)” error when flashing ESP32 firmware?
When flashing ESP32 firmware with Thonny or uploading code to ESP32 using the Arduino IDE, you may encounter the following error:
A fatal error occurred: Failed to connect to ESP32: Wrong boot mode detected (0x13)! The chip needs to be in download mode.
This does not indicate a hardware problem with your ESP32 board. This issue may occur when the computer fails to automatically put the ESP32 into download mode during the flashing process.
Cause
ESP32 must be in download mode to flash firmware successfully. In some environments, the automatic download trigger may not work as expected due to timing differences in USB drivers, USB port behavior, or how the operating system handles DTR/RTS signals. As a result, the ESP32 remains in normal run mode, causing the flashing to fail.
Solution
If you encounter this error, you can manually enter download mode before flashing:
  • Using buttons (BOOT + EN/RST): Press and hold the BOOT button, then short press EN (or RST), and finally release BOOT. This forces the ESP32 into download mode.
  • Using a jumper wire: Connect GPIO0 to GND with a jumper wire, then press EN (or power cycle the board) to enter download mode. After flashing, remove the jumper wire to allow normal boot.
Notes
  • Make sure to use a proper data cable (not a charge-only cable).
  • If the problem persists, try changing the USB port, updating the USB-to-serial driver, or lowering the baud rate (e.g., 115200).
