WiFi-Controlled LED (Access Point)
This project allows you to control an LED light through a web interface. The Arduino board acts as a WiFi access point, creating its own local network that you can connect to with a web browser. Once connected, you can navigate to the device’s IP address using the web browser, where you’ll find options to turn an LED (connected to the board’s pin 13) on and off. The project provides real-time feedback on the LED status via the Serial Monitor, making it easier to debug and understand the flow of operations.
1. Upload the code
Open the 01-wifi_ap.ino file under the path of elite-explorer-kit-main\r4_new_feature\01-wifi_ap, or copy this code into Arduino IDE.
Wi-Fi® support is enabled via the built-in WiFiS3 library that is shipped with the Arduino UNO R4 Core. Installing the core automatically installs the WiFiS3 library.
You still need to create or modify arduino_secrets.h, replace SECRET_SSID and SECRET_PASS with the name and password of your WiFi access point. The file should contain:
arduino_secrets.h
//arduino_secrets.h header file
#define SECRET_SSID "your_ssid"
#define SECRET_PASS "your_password"
01-wifi_ap.ino
  1/*
  2  WiFi Web Server LED Blink
  4  A simple web server that lets you blink an LED via the web.
  5  This sketch will create a new access point (with no password).
  6  It will then launch a new server and print out the IP address
  7  to the Serial Monitor. From there, you can open that address in a web browser
  8  to turn on and off the LED on pin 13.
  9
 10  If the IP address of your board is yourAddress:
 11    http://yourAddress/H turns the LED on
 12    http://yourAddress/L turns it off
 13
 14  created 25 Nov 2012
 15  by Tom Igoe
 16  adapted to WiFi AP by Adafruit
 17
 18  Find the full UNO R4 WiFi RTC documentation here:
 19  https://docs.arduino.cc/tutorials/uno-r4-wifi/wifi-examples#access-point
 20 */
 21
 22
 23#include "WiFiS3.h"
 24
 25#include "arduino_secrets.h"
 26
 27///////please enter your sensitive data in the Secret tab/arduino_secrets.h
 28char ssid[] = SECRET_SSID;        // your network SSID (name)
 29char pass[] = SECRET_PASS;        // your network password (use for WPA, or use as key for WEP)
 30int keyIndex = 0;                 // your network key index number (needed only for WEP)
 31
 32int led =  LED_BUILTIN;
 33int status = WL_IDLE_STATUS;
 34WiFiServer server(80);
 35
 36void setup() {
 37  //Initialize serial and wait for port to open:
 38  Serial.begin(9600);
 39  while (!Serial) {
 40    ; // wait for serial port to connect. Needed for native USB port only
 41  }
 42  Serial.println("Access Point Web Server");
 43
 44  pinMode(led, OUTPUT);      // set the LED pin mode
 45
 46  // check for the WiFi module:
 47  if (WiFi.status() == WL_NO_MODULE) {
 48    Serial.println("Communication with WiFi module failed!");
 49    // don't continue
 50    while (true);
 51  }
 52
 53  String fv = WiFi.firmwareVersion();
 54  if (fv < WIFI_FIRMWARE_LATEST_VERSION) {
 55    Serial.println("Please upgrade the firmware");
 56  }
 57
 58  // by default the local IP address will be 192.168.4.1
 59  // you can override it with the following:
 60  WiFi.config(IPAddress(192,48,56,2));
 61
 62  // print the network name (SSID);
 63  Serial.print("Creating access point named: ");
 64  Serial.println(ssid);
 65
 66  // Create open network. Change this line if you want to create an WEP network:
 67  status = WiFi.beginAP(ssid, pass);
 68  if (status != WL_AP_LISTENING) {
 69    Serial.println("Creating access point failed");
 70    // don't continue
 71    while (true);
 72  }
 73
 74  // wait 10 seconds for connection:
 75  delay(10000);
 76
 77  // start the web server on port 80
 78  server.begin();
 79
 80  // you're connected now, so print out the status
 81  printWiFiStatus();
 82}
 83
 84
 85void loop() {
 86
 87  // compare the previous status to the current status
 88  if (status != WiFi.status()) {
 89    // it has changed update the variable
 90    status = WiFi.status();
 91
 92    if (status == WL_AP_CONNECTED) {
 93      // a device has connected to the AP
 94      Serial.println("Device connected to AP");
 95    } else {
 96      // a device has disconnected from the AP, and we are back in listening mode
 97      Serial.println("Device disconnected from AP");
 98    }
 99  }
100
101  WiFiClient client = server.available();   // listen for incoming clients
102
103  if (client) {                             // if you get a client,
104    Serial.println("new client");           // print a message out the serial port
105    String currentLine = "";                // make a String to hold incoming data from the client
106    while (client.connected()) {            // loop while the client's connected
107      delayMicroseconds(10);                // This is required for the Arduino Nano RP2040 Connect - otherwise it will loop so fast that SPI will never be served.
108      if (client.available()) {             // if there's bytes to read from the client,
109        char c = client.read();             // read a byte, then
110        Serial.write(c);                    // print it out to the serial monitor
111        if (c == '\n') {                    // if the byte is a newline character
112
113          // if the current line is blank, you got two newline characters in a row.
114          // that's the end of the client HTTP request, so send a response:
115          if (currentLine.length() == 0) {
116            // HTTP headers always start with a response code (e.g. HTTP/1.1 200 OK)
117            // and a content-type so the client knows what's coming, then a blank line:
118            client.println("HTTP/1.1 200 OK");
119            client.println("Content-type:text/html");
120            client.println();
121
122            // the content of the HTTP response follows the header:
123            client.print("<p style=\"font-size:7vw;\">Click <a href=\"/H\">here</a> turn the LED on<br></p>");
124            client.print("<p style=\"font-size:7vw;\">Click <a href=\"/L\">here</a> turn the LED off<br></p>");
125
126            // The HTTP response ends with another blank line:
127            client.println();
128            // break out of the while loop:
129            break;
130          }
131          else {      // if you got a newline, then clear currentLine:
132            currentLine = "";
133          }
134        }
135        else if (c != '\r') {    // if you got anything else but a carriage return character,
136          currentLine += c;      // add it to the end of the currentLine
137        }
138
139        // Check to see if the client request was "GET /H" or "GET /L":
140        if (currentLine.endsWith("GET /H")) {
141          digitalWrite(led, HIGH);               // GET /H turns the LED on
142        }
143        if (currentLine.endsWith("GET /L")) {
144          digitalWrite(led, LOW);                // GET /L turns the LED off
145        }
146      }
147    }
148    // close the connection:
149    client.stop();
150    Serial.println("client disconnected");
151  }
152}
153
154void printWiFiStatus() {
155  // print the SSID of the network you're attached to:
156  Serial.print("SSID: ");
157  Serial.println(WiFi.SSID());
158
159  // print your WiFi shield's IP address:
160  IPAddress ip = WiFi.localIP();
161  Serial.print("IP Address: ");
162  Serial.println(ip);
163
164  // print where to go in a browser:
165  Serial.print("To see this page in action, open a browser to http://");
166  Serial.println(ip);
167
168}
2. Code explanation
  1. Importing Required Libraries
    Importing the WiFiS3 library for WiFi functionalities and arduino_secrets.h for sensitive data like passwords.
    #include "WiFiS3.h"
  2. Configuration and Variable Initialization
    Define WiFi SSID, password, and key index along with the LED pin and WiFi status.
    int keyIndex = 0;
  3. setup() Function
    Initialize the serial communication and configure the WiFi module.
      // ... setup code ...
      // Create access point
      // ... error handling ...
      server.begin();
    We also check if the firmware version of uno R4 wifi is up to date. If it is not the latest version, a prompt for upgrade will be displayed. You can refer to Update the radio module firmware on your UNO R4 WiFi board for firmware upgrade.
    You may want to modify the following code in order to be able to change the default IP of Arduino.
  4. Main loop() Function
    The loop() function in the Arduino code performs several key operations, specifically:
    1. Checking if a device has connected or disconnected from the access point.
    2. Listening for incoming clients who make HTTP requests.
    3. Reading client data and executing actions based on that data—like turning an LED on or off.
    Here, let’s break down the loop() function to make these steps more understandable.
    1. Checking WiFi Status
      The code first checks if the WiFi status has changed. If a device has connected or disconnected, the serial monitor will display the information accordingly.
        } else {
    2. Listening for Incoming Clients
      WiFiClient client = server.available(); waits for incoming clients.
    3. Handling Client Requests
      Listens for incoming clients and serves them the HTML web page. When a user clicks on the “Click here to turn the LED on” or “Click here to turn the LED off” links on the served webpage, an HTTP GET request is sent to the Arduino server. Specifically, the URLs “http://yourAddress/H” for turning on the LED and “http://yourAddress/L” for turning it off will be accessed.
      if (client) {
        client.println();
      The Arduino code listens for these incoming GET requests. When it detects GET /H at the end of an incoming line of text (HTTP header), it sets the LED connected to pin 13 to HIGH, effectively turning it on. Similarly, if it detects GET /L, it sets the LED to LOW, turning it off.
              currentLine = "";
Reference
