Real-Time Clock
The RTC (Real-Time Clock) is integrated into the UNO R4 WiFi’s microcontroller (RA4M1). The RTC is an autonomous clock module capable of operating even when the main power supply is disconnected, thanks to a backup power source such as a battery. This makes the RTC incredibly versatile for various applications like scheduling timed tasks in home automation systems or time-stamping individual data points in data logging applications.
The UNO R4 WiFi has a VRTC pin that maintains the onboard RTC’s operation even when the board loses power. To utilize this feature, apply a voltage between 1.6 and 3.6 V to the VRTC pin.
Scheduled Repetitive Tasks
In certain use-cases, you may need to execute specific tasks at regular intervals. To establish periodic interrupts, you’ll first need to initialize a periodic callback function. Below is an Arduino code example that uses a periodic interrupt to blink an LED every 2 seconds.
Upload the Code
Open the 03-rtc.ino file located at elite-explorer-kit-main\r4_new_feature\03-rtc, or paste the following code into your Arduino IDE.
1/*
2 This code is for an Arduino Uno R4 board and it toggles an LED on and
3 off every 2 seconds using a Real Time Clock (RTC) for timing. It initializes
4 the RTC, sets a specific time, and establishes a periodic callback to toggle
5 the LED state. When the callback is triggered, it toggles the LED and outputs
6 a debugging message to the serial monitor.
7
8 Board: Arduino Uno R4
9*/
10
11// Include the RTC library
12#include "RTC.h"
13
14volatile bool irqFlag = false; // Flag to indicate a periodic callback.
15bool ledState = false; // Current LED state: true for ON and false for OFF
16const int led = LED_BUILTIN; // Pin number for the built-in LED
17
18void setup() {
19 pinMode(led, OUTPUT); // Configure the LED pin as output
20
21 Serial.begin(9600);
22
23 // Initialize the RTC
24 RTC.begin();
25
26 // Set an arbitrary time to the RTC (required for RTC.setPeriodicCallback to work)
27 RTCTime mytime(30, Month::JUNE, 2023, 13, 37, 00, DayOfWeek::WEDNESDAY, SaveLight::SAVING_TIME_ACTIVE);
28 RTC.setTime(mytime);
29
30 // Set the periodic callback to trigger every 2 seconds
31 if (!RTC.setPeriodicCallback(periodicCallback, Period::ONCE_EVERY_2_SEC)) {
32 Serial.println("ERROR: periodic callback not set");
33 }
34}
35
36void loop() {
37 // Check if the periodic callback has been triggered
38 if (irqFlag) {
39 Serial.println("Timed CallBack"); // Output a debugging message
40 ledState = !ledState; // Toggle the LED state
41 digitalWrite(led, ledState); // Update the LED
42 irqFlag = false; // Reset the flag
43 }
44}
45
46// This is the callback function to be passed to RTC.setPeriodicCallback()
47void periodicCallback() {
48 // Set the flag to true to indicate the callback has been triggered
49 irqFlag = true;
50}
Code Explanation
Initializing Components and Libraries
#include "RTC.h" volatile bool irqFlag = false; bool ledState = false; const int led = LED_BUILTIN; void setup() { pinMode(led, OUTPUT); Serial.begin(9600); RTC.begin(); }
#include "RTC.h": Includes the RTC library.volatile bool irqFlag = false;: Declares a volatile boolean flag.volatileensures that the variable can be safely accessed or modified by an interrupt. For more details onvolatile, refer to Arduino volatile documentation.bool ledState = false;: Declares a boolean to keep track of the LED state.const int led = LED_BUILTIN;: Declares a constant for the built-in LED pin.pinMode(led, OUTPUT);: Sets the LED pin as an output.Serial.begin(9600);: Initializes serial communication at 9600 baud rate.RTC.begin();: Initializes the RTC.
Setting Up the Real-Time Clock
RTCTime mytime(30, Month::JUNE, 2023, 13, 37, 00, DayOfWeek::WEDNESDAY, SaveLight::SAVING_TIME_ACTIVE); RTC.setTime(mytime);
RTCTime mytime(...);: Creates anRTCTimeobject and initializes it with a specific date and time.RTC.setTime(mytime);: Sets the RTC with the initialized time.
Setting and Checking Periodic Callback
if (!RTC.setPeriodicCallback(periodicCallback, Period::ONCE_EVERY_2_SEC)) { Serial.println("ERROR: periodic callback not set"); } void loop() { if (irqFlag) { Serial.println("Timed CallBack"); ledState = !ledState; digitalWrite(led, ledState); irqFlag = false; } } void periodicCallback() { irqFlag = true; }
RTC.setPeriodicCallback(...);: Sets a periodic callback to trigger every 2 seconds.The period can be specified using the following enumerations:ONCE_EVERY_2_SECONCE_EVERY_1_SECN2_TIMES_EVERY_SECN4_TIMES_EVERY_SECN8_TIMES_EVERY_SECN16_TIMES_EVERY_SECN32_TIMES_EVERY_SECN64_TIMES_EVERY_SECN128_TIMES_EVERY_SECN256_TIMES_EVERY_SEC
void loop() {...}: Checks if the callback has been triggered. If so, toggles the LED state.void periodicCallback() {...}: The callback function setsirqFlag = truewhen triggered.
Reference
