7. Follow Your Hand¶
Think of this car as your pet here, and when you will wave to him, it comes running to you.
ITEMS IN THIS KIT
COMPONENT INTRODUCTION
PURCHASE LINK
Arduino Uno R4 Minima
L9110 Motor Driver Module
TT Motor
Ultrasonic Module
Obstacle Avoidance Module
Connect the ultrasonic module and the 2 IR obstacle avoidance modules at the same time.
Wire the ultrasonic to the R4 board as follows.
Ultrasonic Module
R4 Board
Vcc
5V
Trig
Echo
Gnd
GND
The wiring of the 2 IR obstacle avoidance modules to the R4 board is as follows.
Left IR Module
R4 Board
OUT
8
GND
GND
VCC
5V
Right IR Module
R4 Board
OUT
7
GND
GND
VCC
5V
../_images/car_7_8.png
  • Open the 7.follow_your_hand.ino file under the path of 3in1-kit\car_project\7.follow_your_hand.
  • Or upload the code through the Arduino Web Editor.
Place the car on the ground after the code has been uploaded successfully. Place your hand close to 5*10cm in front of the car, and it will follow your hand forward. If you put your hand close to the IR Obstacle module on both sides, it will also turn to the corresponding direction.
How it works?
This project is a combination of the previous two projects 6. Play with Ultrasonic Module and 5. Play with Obstacle Avoidance Module, but the implemented effect is different. The previous 2 projects are detecting an obstacle backwards, but here it is detecting that your hand will follow the forward or turn direction. The workflow of this project is as follows.
  • Read the distance detected by the ultrasonic module and the value of both infrared modules.
  • If the distance is 5~10cm, let the car move with your hand.
  • If the left IR module detects your hand, turn left.
  • If the right IR module detects your hand, turn right.
  • If neither the infrared module nor the ultrasonic module detects your hand, let the car stop.
    float distance = readSensorData();
    int left = digitalRead(leftIR);   // 0: Obstructed  1: Empty
    int right = digitalRead(rightIR);
    int speed = 150;
    if (distance>5 && distance<10){
        moveForward(speed);
    if(!left&&right){
        turnLeft(speed);
    }else if(left&&!right){
        turnRight(speed);
    }else{
        stopMove();
