11. Speed Calibration¶
In getting the car to move forward, you may find that the car does not travel in a straight line. This is because the two motors may not have the same speed at the factory. But we can write offset to the two motors to make their rotational speeds converge.
In this project, we will learn to store the offset into EEPROM, the point of this is that after each calibration, all projects can get the offset value directly from the EEPROM, so that the car can go in a straight line smoothly.
This project is the same wiring as 2. Move by Code.
How to play?
  1. Open the 11.speed_calibration.ino file under the path of 3in1-kit\car_project\11.speed_calibration. Or copy this code into Arduino IDE.
  1. After the code is uploaded successfully, connect the car with 9V battery, put it on the ground and let it move forward to see which side it is offset to.
  • If the car moves to the left front, it means the right motor speed is too fast and needs to be reduced.
    EEPROM.write(1, 100) // 1 means the right motor, 100 means 100% speed, can be set to 90, 95, etc., depending on the actual situation.
  • If the car moves to the right, it means the left motor speed is too fast and needs to be reduced.
    EEPROM.write(0, 100) // 0 means the right motor, 100 means the speed is 100%, can be set to 90, 95, etc., depending on the actual situation. 3.
  1. After modifying the code, upload the code to R4 board to see the effect. Repeat the above steps until the car is almost straight.
  2. This offset will be recorded in EEPROM, you only need to read this offset when you use it in other projects, take 5. Play with Obstacle Avoidance Module as an example.
#include <EEPROM.h>
float leftOffset = 1.0;
float rightOffset = 1.0;
const int A_1B = 5;
const int A_1A = 6;
const int B_1B = 9;
const int B_1A = 10;
const int rightIR = 7;
const int leftIR = 8;
    Serial.begin(9600);
    //motor
    pinMode(A_1B, OUTPUT);
    pinMode(A_1A, OUTPUT);
    pinMode(B_1B, OUTPUT);
    pinMode(B_1A, OUTPUT);
    //IR obstacle
    pinMode(leftIR, INPUT);
    pinMode(rightIR, INPUT);
    leftOffset = EEPROM.read(0) * 0.01;//read the offset of the left motor
    rightOffset = EEPROM.read(1) * 0.01;//read the offset of the right motor
    int left = digitalRead(leftIR);   // 0: Obstructed  1: Empty
    int right = digitalRead(rightIR);
    int speed = 150;
    if (!left && right) {
        backLeft(speed);
    } else if (left && !right) {
        backRight(speed);
    } else if (!left && !right) {
        moveBackward(speed);
    } else {
        moveForward(speed);
void moveForward(int speed) {
    analogWrite(A_1B, 0);
    analogWrite(A_1A, int(speed * leftOffset));
    analogWrite(B_1B, int(speed * rightOffset));
    analogWrite(B_1A, 0);
void moveBackward(int speed) {
    analogWrite(A_1B, speed);
    analogWrite(A_1A, 0);
    analogWrite(B_1B, 0);
    analogWrite(B_1A, speed);
void backLeft(int speed) {
void backRight(int speed) {
