4.4 Measure Soil Moisture¶
In the planting industry, the crops themselves cannot directly obtain the inorganic elements in the soil, Water in the soil acts as a solvent for dissolving these inorganic elements.
Crops absorb soil moisture through the root system, obtain nutrients, and promote growth.
In the process of crop growth and development, the requirements for soil temperature are also different. Therefore, a soil moisture sensor is required.
3 in 1 Starter Kit |
380+ |
COMPONENT INTRODUCTION |
PURCHASE LINK |
Schematic
Open the
4.4.measure_soil_moisture.inofile under the path of3in1-kit\learning_project\4.4.measure_soil_moisture.Or copy this code into Arduino IDE.
Once the code is successfully uploaded, the serial monitor will print out the soil moisture value.
By inserting the module into the soil and watering it, the value of the soil moisture sensor will become smaller.
