4.1 Turn the Knob
Potentiometer is a resistor component with 3 terminals and its resistance value can be adjusted according to some regular variation.
ITEMS IN THIS KIT
COMPONENT INTRODUCTION
PURCHASE LINK
Arduino Uno R4 Minima
Jumper Wires
Potentiometer
Schematic
../_images/circuit_5.1_potentiometer.png
In this example, we use the analog pin (A0) to read the value of the potentiometer. By rotating the axis of the potentiometer, you can change the distribution of resistance among these three pins, changing the voltage on the middle pin. When the resistance between the middle and a outside pin connected to 5V is close to zero (and the resistance between the middle and the other outside pin is close to 10kΩ), the voltage at the middle pin is close to 5V. The reverse operation (the resistance between the middle and a outside pin connected to 5V is close to 10kΩ) will make the voltage at the middle pin be close to 0V.
../_images/4.1_turn_thek_knob_bb.png
  • You can open the file 4.1.turn_the_knob.ino under the path of 3in1-kit\learning_project\4.1.turn_the_knob.
After uploading the codes to the board, you can open the serial monitor to see the reading value of the pin. When rotating the axis of the potentiometer, the serial monitor will print the value 「0」~「1023」.
