3.4 Detect the Line¶
The line tracking module is used to detect whether there are black areas on the ground, such as black lines pasted with electrical tape.
One of its LEDs emits appropriate infrared light to the ground, and the black surface has a relatively strong ability to absorb light and a weaker reflection ability. White surfaces are the opposite. If it detects reflected light, it means the ground is currently white. If not detected, it means black.
That’s how it works.
ITEMS IN THIS KIT
COMPONENT INTRODUCTION
PURCHASE LINK
Arduino Uno R4 Minima
Jumper Wires
Line Tracking Module
Schematic
../_images/circuit_3.4_line.png
The digital pin 2 is used to read the signal of line track module. We get the VCC of the module connected to 5V, GND to GND, OUT to digital pin 2.
../_images/3.4_detect_the_line_bb.png
  • You can open the file 3.4.detect_the_line.ino under the path of 3in1-kit\learning_project\3.4.detect_the_line.
When the line tracking module detects there is black line, there appears [1] on the Serial Monitor; otherwise, [0] is displayed.
