3.1 Reading Button Value
In the previous projects, we used the output function, in this chapter we will use the input function to input read the button value.
ITEMS IN THIS KIT
COMPONENT INTRODUCTION
PURCHASE LINK
Arduino Uno R4 Minima
Jumper Wires
Resistor
Button
Schematic
../_images/circuit_3.1_button.png
One side of the button pin is connected to 5V, and the other side pin is connected to pin 2, so when the button is pressed, pin 2 will be high. However, when the button is not pressed, pin 2 is in a suspended state and may be high or low. In order to get a stable low level when the button is not pressed, pin 2 needs to be reconnected to GND through a 10K pull-down resistor.
../_images/3.1_reading_button_value_bb.png
  • You can open the file 3.1.read_button_value.ino under the path of 3in1-kit\learning_project\3.1.read_button_value.
After the code is uploaded successfully, click the magnifying glass icon in the upper right corner of the Arduino IDE (Serial Monitor).
../_images/sp220614_152922.png
When you press the button, the Serial Monitor will print “1”.
