HARDWARE DESCRIPTION
Features
  • Resolution: 1280x800
  • Plug & Play
  • 10-point Touch Capacitive Screen
  • Power Input: DC 12V/1.5A
  • Power Output: USB Type A 5V/3A
  • Aspect Ratio:8:05
  • Consumption: 7W
  • LCD Type: IPS
  • Speaker: 8Ω/2W
Back
_images/ts10_back.jpg
This is the back of it, with the main board, speakers and touch module pre-installed. To use it, just attach your control board to it and connect all the wires.
Touch Module
_images/touch_module.jpg
There are two types of 4pin connector on the touch module, with the pin serial number shown on the figure.
Here are the definitions of the pins:
  • Pin 1: VDD(5V)
  • Pin 2: D-
  • Pin 3: D+
  • Pin 4:GND
LED Indicators
_images/led_2.jpg
  • Power on the screen, after the Signal LED flashes one time, it lights on continuously; and the Power LED lights on immediately.
  • If there’s no HDMI signal, only the Power LED will turn on.
  • If there’s an HDMI signal, these two LEDs will turn on.
  • If you press the power button, the Signal LED will turn off and the Power LED will keep turning on.
  • If you remove the power adapter, both of the two LEDs will turn off.
Buttons
_images/buttons.jpg
Buttons on the main board and their functions:
Working
Sleep
Menu
Volume Adjust
Brightness Adjust
Power
Enter Sleep state
Enter Working state
Enter Sleep state
Enter Sleep state
Enter Sleep state
Menu
Open the Menu
Confirm
Increase Volume
Increase Volume
Increase Brightness
Decrease Volume
Decrease Volume
Decrease Brightness
Back
Open the Brightness adjust
back
back
back
Ports
_images/port2.jpg
On one side of the main board there are ports of HDMI input, 12V power input, and 5V/3A USB power output and Speaker Port.
