1.3 Install libraries (Important)
Many libraries are available directly through the Arduino Library Manager. You can access the Library Manager by following these steps:
In the Library Manager, you can search for the desired library by name or browse through different categories.
In projects where library installation is required, there will be prompts indicating which libraries to install. Follow the instructions provided, such as “The DHT sensor library library is used here, you can install it from the Library Manager.” Simply install the recommended libraries as prompted.
../../_images/install_lib32.png
Once you find the library you want to install, click on it and then click the INSTALL button.
../../_images/install_lib22.png
The Arduino IDE will automatically download and install the library for you.
The libraries installed can be found in the default library directory of the Arduino IDE, which is usually located at C:\Users\xxx\Documents\Arduino\libraries.
If your library directory is different, you can check it by going to File -> Preferences.
../../_images/install_lib12.png
