2.1.2 Micro Switchο
Introductionο
In this project, we will learn how to use Micro Switch. A Micro Switch is a small, very sensitive switch which requires minimum compression to activate. Because they are reliable and sensitive, micro switches are often used as a safety device.
They are used to prevent doors from closing if something or someone is in the way and other applications similar.
Required Componentsο
Raphael Kit |
337 |
COMPONENT INTRODUCTION |
PURCHASE LINK |
Schematic Diagramο
Connect the left pin of the Micro Switch to GPIO17, and two LEDs to pin GPIO22 and GPIO27 respectively. Then when you press and release the move arm of the Micro Switch, you can see the two LEDs light up alternately.
Experimental Proceduresο
Step 1: Build the circuit.
cd ~/raphael-kit/c/2.1.2
Step 3: Compile.
gcc 2.1.2_MicroSwitch.c -lwiringPi
Step 4: Run the executable file above.
While the code is running, press the Micro Switch, then the yellow LED lights up; release the moving arm, the red LED turns on.
#include <wiringPi.h>
#include <stdio.h>
#define microPin 0
#define led1 3
#define led2 2
int main(void)
// When initialize wiring failed, print message to screen
if(wiringPiSetup() == -1){
pinMode(microPin, INPUT);
pinMode(led1, OUTPUT);
pinMode(led2, OUTPUT);
// micro switch high, led1 on
if(digitalRead(microPin) == 1){
digitalWrite(led1, LOW);
digitalWrite(led2, HIGH);
printf("LED1 on\n");
// micro switch low, led2 on
if(digitalRead(microPin) == 0){
digitalWrite(led2, LOW);
digitalWrite(led1, HIGH);
printf(".....LED2 on\n");
delay(500);
Code Explanation
if(digitalRead(slidePin) == 1){
When the moving arm of the micro switch is released, the left pin is connected to the right pin; at this time, a high level will be read on GPIO17, and then LED1 will be on and LED2 will be off.
if(digitalRead(slidePin) == 0){
When the move arm is pressed, the left pin and the middle pin are connected. At this point a low level will be read on GPIO17, then turns LED2 on and LED1 off.
