1.3.2 Servo
In this project, we will learn how to make the servo rotate.
../_images/list_1.3.2.png
ITEMS IN THIS KIT
COMPONENT INTRODUCTION
PURCHASE LINK
GPIO Extension Board
Jumper Wires
Servo
Schematic Diagram
../_images/image337.png
Experimental Procedures
Step 1: Build the circuit.
../_images/image125.png
cd ~/raphael-kit/c/1.3.2
Step 3: Compile the code.
gcc 1.3.2_Servo.c -lwiringPi
After the program is executed, the servo will rotate from 0 degrees to 180 degrees, and then from 180 degrees to 0 degrees, circularly.
#include <wiringPi.h>
#include <softPwm.h>
#include <stdio.h>
#define ServoPin    1       //define the servo to GPIO1
long Map(long value,long fromLow,long fromHigh,long toLow,long toHigh){
    return (toHigh-toLow)*(value-fromLow) / (fromHigh-fromLow) + toLow;
void setAngle(int pin, int angle){    //Create a funtion to control the angle of the servo.
    if(angle < 0)
        angle = 0;
    if(angle > 180)
        angle = 180;
    softPwmWrite(pin,Map(angle, 0, 180, 5, 25));
int main(void)
    int i;
    softPwmCreate(ServoPin, 0, 200);       //initialize PMW pin of servo
        for(i=0;i<181;i++){     // Let servo rotate from 0 to 180.                  setAngle(ServoPin,i);
            delay(2);
        delay(1000);
        for(i=181;i>-1;i--){        // Let servo rotate from 180 to 0.              setAngle(ServoPin,i);
            delay(2);
        delay(1000);
Code Explanation
Create a Map() function to map value in the following code.
    if(angle < 0)
        angle = 0;
    if(angle > 180)
        angle = 180;
Create a funtion, setAngle() to write angle to the servo.
softPwmWrite(pin,Map(angle,0,180,5,25));
This function can change the duty cycle of the PWM.
To make the servo rotate to 0 ~ 180 °, the pulse width should change within the range of 0.5ms ~ 2.5ms when the period is 20ms; in the function, softPwmCreate() , we have set that the period is 200x100us=20ms, thus we need to map 0 ~ 180 to 5x100us ~ 25x100us.
The prototype of this function is shown below.
int softPwmCreate(int pin,int initialValue,int pwmRange);
  • pin: Any GPIO pin of Raspberry Pi can be set as PWM pin.
  • initialValue: The initial pulse width is that initialValue times 100us.
  • pwmRange: the period of PWM is that pwmRange times 100us.
Phenomenon Picture
../_images/image126.jpeg
