2. Configuring Your Home Assistant¶
1. Enable the I2C Interface
This involves activating the I2C interface on your device.
Remove and then reinsert the SD card into your computer. Open the File Explorer and locate the SD card named
hassos-boot
.In the root directory, create a new folder named
CONFIG
.Within the
CONFIG
folder, make a subfolder titledmodules
.Turn on the display of file extensions in your settings.
Inside the
modules
subfolder, create a text file and rename it torpi-i2c.conf
. Confirm the extension change when prompted.Edit
rpi-i2c.conf
to include the following line:i2c-dev
Save and exit the file.
2. Setting Up WiFi
Now, let’s set up the WiFi connection.
Skip this step if you prefer using a wired network connection.
In the
CONFIG
folder, create a new folder namednetwork
.Inside the
network
folder, create a text file and name itmy-network
(leave out the file extension).Enter the following configuration in the
my-network
file, substitutingMY_SSID
andMY_WLAN_SECRET_KEY
with your WiFi network’s details:[connection] id=my-network uuid=72111c67-4a5d-4d5c-925e-f8ee26efb3c3 type=802-11-wireless [802-11-wireless] mode=infrastructure ssid=MY_SSID # Uncomment if your SSID is hidden #hidden=true [802-11-wireless-security] auth-alg=open key-mgmt=wpa-psk psk=MY_WLAN_SECRET_KEY [ipv4] method=auto [ipv6] addr-gen-mode=stable-privacy method=auto
Save and close the file.
3. Adjusting Configuration
In the
hassos-boot
directory, find and open theconfig.txt
file.Append the following settings at the end of the file:
dtparam=i2c_vc=on dtparam=i2c_arm=on dtoverlay=gpio-poweroff,gpio_pin=26,active_low=0 dtoverlay=gpio-ir,gpio_pin=13
4. Accessing Home Assistant
Eject the microSD card from your computer and insert it into your Raspberry Pi. Connect the power supply (and Ethernet cable, if applicable).
From your computer, go to homeassistant.local:8123
Initial setup of Home Assistant may take some time during first use.
5. Creating Your Account
Follow the on-screen instructions to create your user account. This is the account you’ll use to access the Home Assistant interface.
Proceed through the prompts to set your location and other preferences. You may be asked to install detected devices; you can choose to skip this for now by selecting FINISH.
