4. View Data from SPC Dashboard¶
If you select the Show in sidebar option in the Pironman U1 add-on and then refresh the webpage, you will be able to open the Pironman U1 dashboard from the sidebar.
The Dashboard will include the following:
External: Displays the status of the external USB power (Plugged in or Unplugged), its voltage, current, and power.
Fan: Shows the fan status, mode, speed, and the current temperature of the Raspberry Pi.
You can manually turn the fan on or off and select different rotation modes for it.
Battery: Displays the battery’s percentage, charging status, voltage, current, and power.
When an external USB power source is plugged in, the battery is in charging mode, showing its voltage, charging current, and power.
When the external USB is not plugged in, the current and power are negative, indicating the battery’s output current and power.
Raspberry Pi Power: Displays the power supply to the Raspberry Pi (External or battery), its voltage, current, and power.
Storage: Displays the storage capacity of a Raspberry Pi, showing various disk partitions with their used and available space.
Memory: Shows the Raspberry Pi’s RAM usage and percentage.
Processor: Illustrates the Raspberry Pi’s CPU performance, including the status of its four cores, operating frequencies, and CPU usage percentage.
Network: Displays the current network connection type, upload, and download speeds.
You can also switch this page to a white mode.
