Python Example Code Analysis¶
Program Structure Framework¶
keyboard_control.py¶
In the code, we use readchar and readkey to get the input state of the key, then we assign some functions to the keys by using if statement.
You can Modify/Reset/Copy/Run/Stop the code below. But before that, you need to go to source code path like picar-4wd/examples. After modifying the code, you can run it directly to see the effect.
import picar_4wd as fc
import sys
import tty
import termios
import asyncio
power_val = 50
key = 'status'
print("If you want to quit.Please press q")
def readchar():
fd = sys.stdin.fileno()
old_settings = termios.tcgetattr(fd)
tty.setraw(sys.stdin.fileno())
ch = sys.stdin.read(1)
finally:
termios.tcsetattr(fd, termios.TCSADRAIN, old_settings)
return ch
def readkey(getchar_fn=None):
getchar = getchar_fn or readchar
c1 = getchar()
if ord(c1) != 0x1b:
return c1
c2 = getchar()
if ord(c2) != 0x5b:
return c1
c3 = getchar()
return chr(0x10 + ord(c3) - 65)
def Keyborad_control():
global power_val
key=readkey()
if key=='6':
if power_val <=90:
power_val += 10
print("power_val:",power_val)
elif key=='4':
if power_val >=10:
power_val -= 10
if key=='w':
fc.forward(power_val)
elif key=='a':
fc.turn_left(power_val)
elif key=='s':
fc.backward(power_val)
elif key=='d':
fc.turn_right(power_val)
fc.stop()
if key=='q':
print("quit")
break
if __name__ == '__main__':
Keyborad_control()
obstacle_avoidance.py¶
In the code, the distance measurement radar (ultrasonic + servo) will take sample for 11 times in total (once every 18°). Then it makes judgement on the distance states of the fourth and the seventh sampling. If radar indicates no obstacle(the returned value is 2), the car will continue moving ahead, or else the car turn right to get around the obstacle.
Check “scan_step()”, “get_status_at()” in the “_init_.py” for more details about the judgement on radar sampling and distance state.
speed = 30
def main():
scan_list = fc.scan_step(35)
if not scan_list:
continue
tmp = scan_list[3:7]
print(tmp)
if tmp != [2,2,2,2]:
fc.turn_right(speed)
fc.forward(speed)
if __name__ == "__main__":
main()
finally:
fc.stop()
track_line.py¶
In this code, grayscale sensor module will judge the gray level of the floor under the car’s head. The car adjusts the directions according to the detection values of these three detectors to follow the black line.
About Grayscale judgement, refer to “get_line_status()” in “_init_.py” for more details.
Track_line_speed = 20
def Track_line():
gs_list = fc.get_grayscale_list()
if fc.get_line_status(400,gs_list) == 0:
fc.forward(Track_line_speed)
elif fc.get_line_status(400,gs_list) == -1:
fc.turn_left(Track_line_speed)
elif fc.get_line_status(400,gs_list) == 1:
fc.turn_right(Track_line_speed)
if __name__=='__main__':
Track_line()
follow.py¶
In the code, the ultrasonic module will take sample to form an array containing 11 elements; the module detects once every 18° and puts the distance state (0,1,2) of every angle into the array. If there is something obstructive at the right front, the detection value is [22222211122].
The array takes the 2 as a delimiter to divide the array anew. The examples above will be divided into several null elements and a [111]- value element.
The corresponding angular range of the element with a value [111] is 108°~144° (0°+18°*6=108°, 0°+18°*8=144°), and the car will turn its angle into a median 126°((144+108)/2)
Judge the distance, and keep the car away from the object about 10cm.
Refer to “scan_step()” and “get_status_at()” in “_init_.py” to get more details about radar sampling and the distance state judgement.
speed = 30
def main():
scan_list = fc.scan_step(23)
# print(scan_list)
if not scan_list:
continue
scan_list = [str(i) for i in scan_list]
scan_list = "".join(scan_list)
paths = scan_list.split("2")
length_list = []
for path in paths:
length_list.append(len(path))
# print(length_list)
if max(length_list) == 0:
fc.stop()
i = length_list.index(max(length_list))
pos = scan_list.index(paths[i])
pos += (len(paths[i]) - 1) / 2
# pos = int(pos)
delta = len(scan_list) / 3
# delta *= us_step/abs(us_step)
if pos < delta:
fc.turn_left(speed)
elif pos > 2 * delta:
if scan_list[int(len(scan_list)/2-1)] == "0":
fc.backward(speed)
fc.forward(speed)
main()
finally:
fc.stop()
