8.5 Cloud Calling System with @MQTT
Message Queuing Telemetry Transport (MQTT) is a simple messaging protocol. It is also the most common messaging protocol for the Internet of Things (IoT).
MQTT protocols define the way IoT devices transfer data. They are event-driven and interconnected using the Pub/Sub model. The sender (Publisher) and the receiver (Subscriber) communicate via Topics. A device publishes a message on a specific topic, and all devices subscribed to that topic receive the message.
In this section, a service bell system will be made using Pico W, HiveMQ (a free public MQTT broker service), and four buttons. The four buttons mean four tables in the restaurant, and you will be able to see which table’s guests need service on HiveMQ when the customer presses the button.
1. Required Components
ITEMS IN THIS KIT
Kepler Kit
450+
Kepler Ultimate Kit
SN
COMPONENT
QUANTITY
Getting to Know Pico W
Micro USB Cable
Jumper Wires
Several
Resistor
4(10KΩ)
Button
Li-po Charger Module
Power Pack
Battery Holder
2. Build the Circuit
Warning
Make sure your Li-po Charger Module is connected as shown in the diagram. Otherwise, a short circuit will likely damage your battery and circuitry.
../../_images/5.mqtt_pub.png
3. Visit HiveMQ
HiveMQ is an MQTT broker and client-based messaging platform that enables fast, efficient and reliable data transfer to IoT devices.。
  1. Open HiveMQ Web Client in your browser.
  2. Connects the client to the default public proxy.
    ../../_images/mqtt-1.png
  3. Click on Add New Topic Subscription.
    ../../_images/mqtt-2.png
  4. Fill in the topics you want to follow and click Subscribe. The topics set here should be more personal to avoid getting messages from other users, and pay attention to case sensitive.
    ../../_images/mqtt-3.png
4. Install the MQTT Module
Before we can start the project, we need to install the MQTT module for Pico W.
  1. Connect to the network by running do_connect() in the Shell, which we wrote earlier.
    • Type the following commands into the Shell and press Enter to run them.
    • If you don’t have do_connect.py and secrets.py scripts in your Pico W, please refer to 8.1 Access to the Network to create them.
    from do_connect import *
    do_connect()
  2. After a successful network connection, import the mip module in the shell and use mip to install the umqtt.simple module, which is a simplified MQTT client for MicroPython.
    import mip
    mip.install('umqtt.simple')
  3. You will see that the umqtt module is installed under the /lib/ path of Pico W after completion.
    ../../_images/5_calling_system1.png
5. Run the Script
  1. Open the 5_mqtt_publish.py file under the path of kepler-kit-main/iot.
  2. Click the Run current script button or press F5 to run it.
    ../../_images/5_calling_system2.png
  3. Go back to HiveMQ Web Client again and when you press one of the buttons on the breadboard, you will be able to see the Messages prompt on HiveMQ.
    ../../_images/mqtt-4.png
  4. If you want this script to be able to boot up, you can save it to the Raspberry Pi Pico W as main.py.
How it works?
The Raspberry Pi Pico W needs to be connected to the Internet, as described in 8.1 Access to the Network. For this project, just use it.
do_connect()
Initialize 4 button pins.
sensor1 = Pin(16, Pin.IN)
sensor2 = Pin(17, Pin.IN)
sensor3 = Pin(18, Pin.IN)
sensor4 = Pin(19, Pin.IN)
Create two variables to store the URL and client ID of the MQTT broker we will use to connect to it. Since we are using a public broker, our client ID will not be used, even if one is required.
mqtt_server = 'broker.hivemq.com'
client_id = 'Jimmy'
Connect to the MQTT agent and hold for one hour. If it fails, reset the Pico W.
    client = MQTTClient(client_id, mqtt_server, keepalive=3600)
    client.connect()
    print('Connected to %s MQTT Broker'%(mqtt_server))
except OSError as e:
    print('Failed to connect to the MQTT Broker. Reconnecting...')
    time.sleep(5)
    machine.reset()
Create a variable topic, which is the topic that the subscriber needs to follow. It should be the same as the topic filled in step 4 of 2. Visit HiveMQ above. Incidentally, b here converts string to byte, because MQTT is a binary based protocol were the control elements are binary bytes and not text strings.
topic = b'SunFounder MQTT Test'
Set interrupts for each button. When a button is pressed, a message is posted under topic.
def press1(pin):
    message = b'button 1 is pressed'
    client.publish(topic, message)
    print(message)
sensor1.irq(trigger=machine.Pin.IRQ_RISING, handler=press1)
