πŸ‘‰ Ready to explore and create with us? Click [here] and join today!
Installing the Operating System
Before using your Raspberry Pi, you need to install Raspberry Pi OS onto a microSD card. This guide explains how to do that using Raspberry Pi Imager in a simple, beginner-friendly way.
  • A computer (Windows, macOS, or Linux)
  • A microSD card (16GB or larger; recommended brands: SanDisk, Samsung)
  • A microSD card reader
Install Raspberry Pi Imager
  1. Visit the official Raspberry Pi Imager download page: Raspberry Pi Imager. Download the correct installer for your operating system.
    ../_images/imager_download.png
  2. Follow the installation prompts (language, install path, confirmation). After installation, launch Raspberry Pi Imager from your desktop or applications menu.
    ../_images/imager_install.png
Download the Exclusive Image File
Download the AI ​​Fusion Lab Kit operating system image file: Raspberry Pi OS with AI Fusion Lab Kit。
../_images/fusion_kit_imager_download.png
This image is based on Raspberry Pi OS and comes with the AI Fusion Lab Kit pre-integrated into the system. It includes all the necessary software, example code, and related configurations required for the AI Fusion Lab Kit. By using this image, you can skip certain setup steps described in the documentation.
If you prefer to use a native Raspberry Pi OS for manual configuration, please install: Raspberry Pi OS (Legacy, 64-bit) (Bookworm, Debian 12)
Install the OS to the microSD Card
  1. Insert your microSD card into your computer using a card reader. Back up any important data before proceeding.
    ../_images/insert_sd.png
  2. When Raspberry Pi Imager opens, you will see the Device page. Select your Raspberry Pi model from the list (e.g., Raspberry Pi 5, 4, 3, or Zero 2W).
    ../_images/imager_device.png
  1. Go to the OS section and choose the Use custom
    ../_images/fusion_kit_imager1.png
    And select the downloaded image file ai.fusion.lab.kit-bookworm.64.full.20xx.xx.xx-latest.zip.
    ../_images/fusion_kit_imager2.png
  1. In the Storage section, select your microSD card.
    ../_images/imager_storage.png
Write the OS Image
  1. Review all settings and click WRITE.
    ../_images/imager_writing.png
  2. If the card already contains data, Raspberry Pi Imager will show a warning that all data on the device will be erased. Double-check that you selected the correct drive, then click I UNDERSTAND, ERASE AND WRITE to continue.
    ../_images/imager_erase.png
  3. Wait for the writing and verification to finish. When it is done, Raspberry Pi Imager will show Write complete! and a summary of your choices. The storage device will be ejected automatically so you can remove it safely.
    ../_images/imager_finish.png
  4. Remove the microSD card and insert it into the slot on the underside of your Raspberry Pi. Your Raspberry Pi is now ready to boot with the new OS!
    ../_images/os_sd_to_pi.jpg
