Play on Other Programming PlatformsΒΆ
This chapter is used to set up Raspberry Pi, from configure the Raspberry Pi environment to download and run the sample python code of X Sense HAT.
You must burn the Ezblock system first. If you use Raspberry Pi OS, the sample codes we provided for X Sense HAT will not be available.
