FAQΒΆ
After finishing the example of x-sense-hat, the pattern of rgb dot matrix may remain and the motor still vibrates.
A: This is normal.
2.The use of the MPU9250 module will be affected by the surrounding magnetic field.
A: In order to read the value of the MPU9250 module more accurately, you can remove the speaker of the x-sense-hat.
