Download Code and Add Libraries
Download the Code
Download the relevant code from the link below.
Add Libraries
What is Library?
A library, gathering some function definitions and header files, usually contains two files: .h (header file, including function statement, Macro definition, constructor definition, etc.) and .cpp (execution file, with function implementation, variable definition, and so on). When you need to use a function in some library, you just need to add a header file (e.g. #include <dht.h>), and then call that function. This can make your code more concise. If you don’t want to use the library, you can also write that function definition directly. Though as a result, the code will be long and inconvenient to read.
Add libraries
Some libraries are already built in the Arduino IDE, when some others may need to be added. So now let’s see how to add one. There are 2 methods for that.
Method 1 Add .ZIP Library
Directly import the library in Arduino IDE (take Dht as an example below). The advantage of this method is easy to understand and operate, but on the other hand, only one library can be imported at a time. So it is inconvenient when you need to add quite a lot of libraries.
Step 1: Select Sketch -> Include Library -> Add ZIP Library.
../../_images/image291.png
Step 2: Find Library folder, Click Open.
../../_images/image292.png
Step 3: When you see Library added to your libraries. Check “Include library” menu, it means you have added the library successfully. Please use the same method to add other libraries then.
../../_images/image293.png
Method 2 Manually Add
You can also try to put the library in the libraries folder of your sketchbook by yourself. This method can copy all libraries and add them at a time, but first you need to find the path where the libraries folder is located.
Step 1: You can find or change the location of your libraries folder at File > Preferences > Sketchbook location.
../../_images/image294.png
Step 2: Go to the directory sunfounder_vincent_kit_for_arduino/library and copy all the folders inside.
../../_images/image295.png
Step 3: Go to the location of your libraries folder(find from Arduino IDE), click to open it.
../../_images/image296.png
Step 4: Paste all the libraries copied before to the libraries folder.
../../_images/image297.png
There is also a way to use the Library Manager, but the libraries added using this method are not necessarily compatible with the code we provide, so it is not recommended.
Here is the link to the official Arduino tutorial: https://docs.arduino.cc/software/ide-v1/tutorials/installing-libraries
