3.2 Pedestrian Crossing Button
Overview
When pedestrians cross the street, they just need to touch the button on the lamppost of the roadside signal lamp, and the green light above the traffic lane will turn into red then pedestrians can pass safely. Thus, the hard situation of citizens crossing the street is comprehensively resolved. At the same time, when there is no pedestrian to press, the light above the lane that is set for vehicles to pass will always be green, thus greatly improving the use efficiency of the road and traffic capacity.
Components Required
_images/Part_three_2.png
Fritzing Circuit
In this example, 74hc595, 7-Segment, LED, touch sensor are to be connected according to the chart.
_images/Part_three_2_Fritzing_Circuit.png 3.2 Pedestrian Crossing Button_bb
Schematic Diagram
_images/image270.png
Example Explanation
The workflow of the project is as shown in the flow chart. The function of number display of 7-Segment is realized by writing 8 bit data into 74HC595. When there is a need of displaying「0」, the pins abcdef of the segment display will be connected to the high level. The pins, g and dp need to be connected to low level to write「0x3f」(B00111111) in the codes. The complete codes for number display of 7-Segment are as follows.
_images/Part_three_2_Example_Explanation.png
Numbers
Common Cathode
(DP)GFEDCBA
Hex Code
0
00111111
0x3f
0x06
0x5b
0x4f
0x66
0x6d
0x7d
7
00000111
0x07
8
01111111
0x7f
9
01101111
0x6f
Phenomenon Picture
3.02
