2.26 Photoresistor
Overview
In this lesson, you will learn about Photoresistor. Photoresistor is applied in many electronic goods, such as the camera meter, clock radio, alarm device (as beam detector), small night lights, outdoor clock, solar street lamps and etc. Photoresistor is placed in a street lamp to control when the light is turned on. Ambient light falling on the photoresistor causes street lamps to turn on or off.
Components Required
_images/Part_two_26.png
Component Introduction
A photoresistor or photocell is a light-controlled variable resistor. The resistance of a photoresistor decreases with increasing incident light intensity; in other words, it exhibits photo conductivity. A photoresistor can be applied in light-sensitive detector circuits, and light- and darkness-activated switching circuits.
_images/image212.png
Fritzing Circuit
In this example, we use analog pin ( A0 ) to read the value of photoresistor. One pin of photoresistor is connected to 5V, the other is wired up to A0. Besides, a 10kΩ resistor is needed before the other pin is connected to GND.
_images/image213.png
Schematic Diagram
_images/image214.png
After uploading the codes to the Mega2560 board, you can open the serial monitor to see the read value of the pin. When the ambient light becomes stronger, the reading will increase correspondingly, and the pin reading range is 「0」~「1023」. However, according to the environmental conditions and the characteristics of the photoresistor, the actual reading range may be smaller than the theoretical range. For a detailed explanation of the code, refer to 1.5 Analog Read.
Phenomenon Picture
2.27
