2.17 Tilt Switch
Overview
In this lesson, you will learn about tilt switch. Tilt switch can be used to detect whether objects tilt, which is of great value in practical applications. It can be used to judge the tilt of bridges, buildings, transmission line tower and so on, so it has an important guiding function in carrying out maintenance work.
Components Required
_images/Part_two_17.png
Component Introduction
The principle is very simple. When the switch is tilted in a certain angle, the ball inside rolls down and touches the two contacts connected to the pins outside, thus triggering circuits. Otherwise the ball will stay away from the contacts, thus breaking the circuits.
_images/image164.jpeg
Fritzing Circuit
In this example, digital pin 2 is used to read the signal of Tilt Switch.
2.17 Tilt Switch_bb
Schematic Diagram
_images/image166.png
After the codes are uploaded to the Mega2560 board, you can open the serial monitor to see the readings of pins, which displays 「1」 or 「0」 when Tilt Switch is vertical (bringing the internal metal ball into contacting with the Wire Pins) or tilted. For detailed explanation of codes, you can turn to 1.4 Digital Read.
Phenomenon Picture
2.17
