Face DetectionΒΆ
Face detection is the first step in building a face recognition system. It will uniformly calibrate the face according to the key points in the face (such as the position of the eyes, the position of the nose, the position of the mouth, the contour points of the face, etc.) and mark the area containing the face. This technology is widely used in security and other scenarios.
Run the Code
cd /home/pi/pan-tilt-hat/examples
sudo python3 face_detection.py
View the Image
After the code runs, the terminal will display the following prompt:
No desktop !
* Environment: production
* Debug mode: off
Then you can enter http://<your IP>:9000/mjpg in the browser to view the video screen. such as: https://192.168.18.113:9000/mjpg
from vilib import Vilib
from time import sleep
def main():
Vilib.face_detect_switch(True)
sleep(1)
n = Vilib.detect_obj_parameter['human_n']
print("%s faces are found."%n)
sleep(1)
if __name__ == "__main__":
main()
How it works?
Functions related to human face detection:
Vilib.face_detect_switch(True): Switch ON/OFF face detection
The keys of the dictionary and their uses are shown in the following list:
human_x: the x value of the center coordinate of the detected human face, the range is 0~320human_y: the y value of the center coordinate of the detected face, the range is 0~240human_w: the width of the detected human face, the range is 0~320human_h: the height of the detected face, the range is 0~240human_n: the number of detected faces
