Measure Light Intensity¶
A photoresistor or photocell is a light-controlled variable resistor. The resistance of a photo resistor decreases with increasing incident light intensity; in other words, it exhibits photo conductivity.
Therefore, we can use a photoresistor to measure light intensity, and then show it through 5 LEDs.
Schematic¶
Wiring¶
In this experiment, we will use 5 LEDs to show the light intensity. The higher the light intensity is, the more LEDs will light up, vice versa.
Code¶
How it works?¶
const int ledPins[] = {11, 12, 13, 14, 15};
const int photocellPin = A0; //photoresistor attach to A0
int sensorValue = 0; // value read from the sensor
int Level = 0; // sensor value converted into LED 'bars'
First of all, there are still various initialization definitions, setting pins and setting initial values of variables.
In order to quickly set the input/output status and HIGH/LOW for the 5 LEDs in the following code, here we use the array ledPin[]
to define the 5 LEDs connected to the corresponding pins of the Pico.
The element number of the array usually starts from 0. For example, ledPin[0]
refers to GPIO11, and ledPin[4]
refers to GPIO15.
void setup()
Serial.begin(9600); // start serial port at 9600 bps:
for (int i = 0; i < 5; i++)
pinMode(ledPins[i], OUTPUT);// make all the LED pins outputs
In setup()
,using the for()
statement set the 5 pins to OUTPUT. The variable i
is added from 0 to 5, and the pinMode()
function sets pin11 to pin15 to OUTPUT in turn.
sensorValue = analogRead(photocellPin); //read the value of A0
Level = map(sensorValue, 0, 1023, 0, 5); // map to the number of LEDs
Serial.println(Level);
delay(10);
In loop()
, read the analog value of the photocellPin(A0) and store to the variable sensorValue.
The map()
function is used to map 0-1023 to 0-5. It means that the value range of the photoresistor (0-1023) is equally divided into 5 levels, 0-204.8 belongs to Level 0, 204.9-409.6 belongs to Level 1, and 819.2-1023 belong to Level 4.
If the value of variable sensorValue
is 300 at this time, then Level
is equal to 1.
if (i <= Level ) //When i is smaller than Level, run the following code.
digitalWrite(ledPins[i], HIGH); // turn on LEDs less than the level
else
digitalWrite(ledPins[i], LOW); // turn off LEDs higher than level
Now we need to find a way to display the brightness level at this time with LEDs.
The for()
statement is used here to perform loop detection in the ledPin[]
array. If the element bit in the array is less than the value of Level
, the corresponding GPIO is set to high level, that is, the corresponding LED is lit.
If Level
is equal to 1, turn on the LEDs on GPIO11 and GPIO12.
