.. note:: Hello, welcome to the SunFounder Raspberry Pi & Arduino & ESP32 Enthusiasts Community on Facebook! Dive deeper into Raspberry Pi, Arduino, and ESP32 with fellow enthusiasts. **Why Join?** - **Expert Support**: Solve post-sale issues and technical challenges with help from our community and team. - **Learn & Share**: Exchange tips and tutorials to enhance your skills. - **Exclusive Previews**: Get early access to new product announcements and sneak peeks. - **Special Discounts**: Enjoy exclusive discounts on our newest products. - **Festive Promotions and Giveaways**: Take part in giveaways and holiday promotions. 👉 Ready to explore and create with us? Click [|link_sf_facebook|] and join today! Read from Ultrasonic Module =============================== In this project, we use ultrasonic sensors to measure distance and display the readings on the I2C LCD1602. .. image:: img/ultrasonic.jpg **Steps** #. In this project, an I2C LCD1602 is used, so it's necessary to download the relevant libraries to make it work. .. code-block:: shell cd ~/ wget https://github.com/sunfounder/raphael-kit/blob/master/python/LCD1602.py #. Install ``smbus2`` for I2C. .. code-block:: shell sudo pip3 install smbus2 #. Save the following code to your Raspberry Pi and give it a name, for example, ``ultrasonic.ty``. .. code-block:: python from robot_hat import ADC, Ultrasonic, Pin import LCD1602 import time # Create ADC object for photoresistor a0 = ADC(0) # Create Ultrasonic object us = Ultrasonic(Pin("D2"), Pin("D3")) //Trig to digital pin 2, echo to pin 3 def setup(): # Initialize LCD1602 LCD1602.init(0x27, 1) # Initial message on LCD LCD1602.write(0, 0, 'Measuring...') time.sleep(2) def destroy(): # Clear the LCD display LCD1602.clear() def loop(): while True: # Read distance from ultrasonic sensor distance = us.read() # Display the distance on the LCD if distance != -1: # Display the valid distance on the LCD LCD1602.write(0, 0, 'Dist: %.2f cm ' % distance) # Update every 0.5 seconds time.sleep(0.2) if __name__ == '__main__': setup() try: loop() except KeyboardInterrupt: destroy() except Exception as e: # Clear the LCD and print error message in case of an exception destroy() print("Error:", e) #. Use the command ``sudo python3 ultrasonic.ty`` to run this code.
