.. note:: Hello, welcome to the SunFounder Raspberry Pi & Arduino & ESP32 Enthusiasts Community on Facebook! Dive deeper into Raspberry Pi, Arduino, and ESP32 with fellow enthusiasts. **Why Join?** - **Expert Support**: Solve post-sale issues and technical challenges with help from our community and team. - **Learn & Share**: Exchange tips and tutorials to enhance your skills. - **Exclusive Previews**: Get early access to new product announcements and sneak peeks. - **Special Discounts**: Enjoy exclusive discounts on our newest products. - **Festive Promotions and Giveaways**: Take part in giveaways and holiday promotions. 👉 Ready to explore and create with us? Click [|link_sf_facebook|] and join today! Plant Monitor ====================== In this project, we detect both light intensity and soil moisture levels, and display them on the I2C LCD1602 . When you feel that the soil moisture is insufficient, you can press the button module to water the potted plant. .. image:: img/plant_monitor.jpg **Steps** #. In this project, an I2C LCD1602 is used, so it's necessary to download the relevant libraries to make it work. .. code-block:: shell cd ~/ wget https://github.com/sunfounder/raphael-kit/blob/master/python/LCD1602.py #. Install ``smbus2`` for I2C. .. code-block:: shell sudo pip3 install smbus2 #. Save the following code to your Raspberry Pi and give it a name, for example, ``plant_monitor.ty``. .. code-block:: python from robot_hat import ADC, Motors, Pin import LCD1602 import time import threading from robot_hat.utils import reset_mcu reset_mcu() time.sleep(.1) # Initialize objects light_sensor = ADC(1) moisture_sensor = ADC(0) motors = Motors() button = Pin('D0') # Thread running flag running = True def init_lcd(): LCD1602.init(0x27, 1) time.sleep(2) def update_lcd(light_value, moisture_value): LCD1602.write(0, 0, 'Light: %d ' % light_value) LCD1602.write(0, 1, 'Moisture: %d ' % moisture_value) def read_sensors(): light_value = light_sensor.read() time.sleep(0.2) moisture_value = moisture_sensor.read() time.sleep(0.2) return light_value, moisture_value def control_motor(): global running while running: button_pressed = button.value() == 0 if button_pressed: motors[1].speed(80) time.sleep(0.1) else: motors[1].speed(0) time.sleep(0.1) time.sleep(0.1) def setup(): init_lcd() def destroy(): global running running = False LCD1602.clear() def loop(): global running while running: light_value, moisture_value = read_sensors() update_lcd(light_value, moisture_value) time.sleep(.2) if __name__ == '__main__': try: setup() motor_thread = threading.Thread(target=control_motor) motor_thread.start() loop() except KeyboardInterrupt: motor_thread.join() # Wait for motor_thread to finish print("Program stopped") except Exception as e: print("Error:", e) finally: motors[1].speed(0) time.sleep(.1) destroy() print('end') #. Use the command ``sudo python3 plant_monitor.ty`` to run this code.
