.. note:: Hello, welcome to the SunFounder Raspberry Pi & Arduino & ESP32 Enthusiasts Community on Facebook! Dive deeper into Raspberry Pi, Arduino, and ESP32 with fellow enthusiasts. **Why Join?** - **Expert Support**: Solve post-sale issues and technical challenges with help from our community and team. - **Learn & Share**: Exchange tips and tutorials to enhance your skills. - **Exclusive Previews**: Get early access to new product announcements and sneak peeks. - **Special Discounts**: Enjoy exclusive discounts on our newest products. - **Festive Promotions and Giveaways**: Take part in giveaways and holiday promotions. 👉 Ready to explore and create with us? Click [|link_sf_facebook|] and join today! Read from Photoresistor Module ================================ In this project, we detect the light intensity and display on the I2C LCD1602. .. image:: img/photoresistor.jpg **Steps** #. In this project, an I2C LCD1602 is used, so it's necessary to download the relevant libraries to make it work. .. code-block:: shell cd ~/ wget https://github.com/sunfounder/raphael-kit/blob/master/python/LCD1602.py #. Install ``smbus2`` for I2C. .. code-block:: shell sudo pip3 install smbus2 #. Save the following code to your Raspberry Pi and give it a name, for example, ``photoresistor.ty``. .. code-block:: python from robot_hat import ADC import LCD1602 import time # Create an ADC object to read the value from the photoresistor a0 = ADC(0) def setup(): # Initialize the LCD1602 LCD1602.init(0x27, 1) time.sleep(2) def destroy(): # Clear the LCD display LCD1602.clear() def loop(): while True: # Read the value from the photoresistor value0 = a0.read() # Display the read value on the LCD LCD1602.write(0, 0, 'Value: %d ' % value0) # Reduce the refresh rate to update once per second time.sleep(0.2) if __name__ == '__main__': setup() try: loop() except KeyboardInterrupt: destroy() except Exception as e: # Clear the LCD and print error message in case of an exception destroy() print("Error:", e) #. Use the command ``sudo python3 photoresistor.ty`` to run this code.
