Greedy SnakeΒΆ
In this project, we use the RGB matrix HAT as the display screen to create a snake eating game by reading the values of the keyboard keys to change the display effect.
_images/snake.png
Run the code
When the program runs, the snake game starts, the keyboard a and d controls the snake to turn left and right. Each time the snake eats a bean, score plus one. When it encounters itself, the score returns to zero. After a period of time, the screen will turn blue, and the score will be displayed after a while. Press q to end the game, and Ctrl+C to exit the program.
cd /home/pi/rgb_matrix/raspberrypi
sudo python3 snake_game.py
You can view the code by typing the command nano snake_game.py in Terminal or by clicking on github-snake_game.py.
How it works?
def readchar():
    fd = sys.stdin.fileno()
    old_settings = termios.tcgetattr(fd)
        tty.setraw(sys.stdin.fileno())
        ch = sys.stdin.read(1)
    finally:
        termios.tcsetattr(fd, termios.TCSADRAIN, old_settings)
    return ch
This function is used to read keyboard input and return the entered characters.
def Keyboard_control():
        global power_val,key
        # key = 'n'
        key=readkey()
        time.sleep(0.22)
        if key=='q':
            print("quit")
            break
Keyboard_control() is used for keyboard control. Call readkey() in an infinite loop to receive the characters input by the keyboard. In addition, the logic of snake-eating is also an infinite loop, then multithreading may be needed when there are multiple infinite loops in a program.
def snake_game():
    global key
    rr = RGB_Matrix(0X74)
    rectangle_coor = [0,0,7,7]
    #rr.draw_rectangle(rectangle_coor,fill=(51,51,0))   #draw a rectangle
    coor_1 = np.asarray([0,2])
    coor_2 = np.asarray([1,2])
    coor_3 = np.asarray([2,2])
    coor_4 = np.asarray([3,2])
    coor_list = [coor_1,coor_2,coor_3,coor_4]
snake_game() is used to represent snake-eating logic. The received key value is a character entered by the keyboard, which needs to be declared as a global variable with globla.
There are three main parts of snake logic:
  • In the first part, when the a or d key is not pressed, first judge the horizontal and vertical, and then judge the forward direction, and then add 1 or subtract 1 to the horizontal or vertical coordinates of each point to achieve the effect of moving up, down, left, and right.
  • The second part is to judge whether the a or d key is pressed. If yes, then judge the horizontal and vertical direction and then determine the forward direction, and then add one or subtract one to the coordinates of each point of the snake head, and the snake head coordinates are additionally processed to achieve the effect of turning the head.
  • The third part is to determine whether the snake head is in contact with dot. If yes, set eat_flag to False and add an element to the list of snakes to achieve the effect of growing snakes.
_images/snake_flow.png
if __name__ == "__main__":
    t1 = threading.Thread(target=Keyborad_control)
    t2 = threading.Thread(target=snake_game)
    t1.setDaemon(True)
    t2.setDaemon(True)
    t1.start()
    t2.start()
The Thread method in the threading ``class can help us create a thread, and the parameter is ``target=function name.
  • SetDaemon(True) sets the thread as a daemon thread. It is generally used in an unimportant thread with an infinite loop.
  • Start() starts the thread.
