Custom Dynamic Shape
Here, based on the previous project, a continuous animation of Pac-Man eating dots will be created.
_images/DIY2shape2.png _images/DIY2shape22.png
Run the code
When the program is running, you will see Pac-Man on the RGB matrix cap move from left to right and leave after eating the rightmost dot.
cd /home/pi/rgb_matrix/raspberrypi
sudo python3 custom_dynamic_shape.py
You can Modify/Reset/Copy/Run/Stop the code below. But before that, you need to go to source code path like rgb_matrix/raspberrypi. After modifying the code, you can run it directly to see the effect.
from rgb_matrix import RGB_Matrix
import random
def pacman(a,k):
    list2 = [[a-4,0,a-1,0],
            [a-5,1,a,1],
            [a-6,2,a-5,2],
            [a-3,2,a-1,2],
            [a-6,3,a-2,3],
            [a-6,4,a-2,4],
            [a-6,5,a-1,5],
            [a-5,6,a,6],
            [a-4,7,a-1,7]]
    fill = (144,192,22)
    for i in range(0,k+1):
        for j in list2:
            rr.draw_line(j,fill)
        rr.display()
        for j in list2:
            rr.draw_line(j,fill=(0,0,0))
        for i in range(0,9):
            list2[i][0] += 1
            list2[i][2] += 1
        time.sleep(0.1)
def pacman2():
    rr.draw_rectangle(rectangle_coor,fill=(0,0,0))
    list = [[2,0,5,0],
            [1,1,6,1],
            [0,2,1,2],
            [3,2,7,2],
            [0,3,7,3],
            [0,4,3,4],
            [0,5,7,5],
            [1,6,6,6],
            [2,7,5,7]]
    fill = (144,192,22)
    for i in list:
        rr.draw_line(i,fill)
    rr.display()
    time.sleep(0.1)
def pac():
    coor = [6,3,7,4]
    rr.draw_rectangle(coor,fill=(82,52,25))
if __name__ == "__main__":
    rr = RGB_Matrix(0X74)
    rectangle_coor = [0,0,7,7]
        pac()
        pacman(0,6)
        pacman2()
        pacman(6,7)
How it works?
    pac()
    pacman(0,6)
    pacman2()
    pacman(6,7)
We can disassemble Pac-Man into three actions, pac() represents the position of the dot.
  • pacman(0,6) means that Pac-Man moves from the far left to the side of the dot.
  • pacman2() mouth closed to indicate the action of eating.
  • pacman(6,7) indicates to continue to leave after eating.
def pacman(a,k):
            [a-5,1,a,1],
            [a-6,2,a-5,2],
            [a-3,2,a-1,2],
            [a-6,3,a-2,3],
            [a-6,4,a-2,4],
            [a-6,5,a-1,5],
            [a-5,6,a,6],
            [a-4,7,a-1,7]]
    fill = (144,192,22)
        for j in list2:
        rr.display()
        for j in list2:
            list2[i][0] += 1
            list2[i][2] += 1
        time.sleep(0.1)
The pacman() function is used to make Pac-man move from the left to the right in an open-mouthed state until it disappears. It has two parameters a and k, a represents the starting position of Pac-man and k represents the number of squares moved to the right.
  • list2 stores the coordinates of Pac-man’s open-mouth state, drawn as lines, with the x-coordinate of each line determined by a.
  • Define a two-level for loop. The inner loop does three things: draws Pac-Man, moves each line in list2 one square to the right, and removes the movement.
  • The outer layer repeats the loop k times, which means Pac-Man moves k squares to the right.
