Christmas TreeΒΆ
In this project, we will use the draw_point() function to make a colorful Christmas tree.
_images/tree2.png
Run the code
When the program runs, you will see a shiny Christmas tree appear on the RGB Matrix HAT.
cd /home/pi/rgb_matrix/raspberrypi
sudo python3 christmas_tree.py
You can Modify/Reset/Copy/Run/Stop the code below. But before that, you need to go to source code path like rgb_matrix/raspberrypi. After modifying the code, you can run it directly to see the effect.
from rgb_matrix import RGB_Matrix
from color import Color
def tree():
    for i in green_coor:
        rr.draw_point(i,(0,255,0))
    for i in yellow_coor:
        rr.draw_point(i,(255,255,0))
    for i in red_coor:
        rr.draw_point(i,(255,0,0))
    rr.display()
def dot():
    col = Color()
    for i in flash_coor:
        rr.draw_point(i,col.random())
    rr.display()
if __name__ == "__main__":
    rr = RGB_Matrix(0X74)
    rectangle_coor = [0,0,7,7]
    green_coor = [[3,0],[4,0],
            [2,1],[3,1],[5,1],
            [1,2],[2,2],[4,2],[5,2],[6,2],
            [1,3],[2,3],[3,3],[4,3],[6,3],
            [2,4],[4,4],[5,4],
            [1,5],[3,5],[5,5],[6,5],
            [1,6],[2,6],[3,6],[4,6],[5,6],[6,6]
    flash_coor = [[4,1],[3,2],[5,3],[3,4],[2,5],[4,5]]
    red_coor = [[0,3],[7,3],[0,6],[7,6]]
    yellow_coor = [[3,0],[4,0],[3,6],[4,6],[3,7],[4,7]]
    tree()
        dot()
How it works?
Import the color class Color, which is a class that we encapsulate to manipulate RGB Matrix HAT colors. In this project, we will use a class function random() to display random colors.
        [2,1],[3,1],[5,1],
        [2,4],[4,4],[5,4],
        [1,6],[2,6],[3,6],[4,6],[5,6],[6,6]]
Divide the Christmas tree into four parts, the red part, the yellow part, the green part, and the blinking part, so we need four lists to store these coordinates.
def tree():
    for i in red_coor:
    rr.display()
Define a tree() function to draw the green(0, 255, 0), yellow(255, 255, 0) and red(255, 0, 0) parts of the Christmas tree.
def dot():
    col = Color()
    for i in coor:
    rr.display()
For the blinking points in the Christmas tree, we can use the random() function in the Color class to achieve. The function of random() is to return a random RGB value, that is, to display random colors in a loop to achieve a blinking effect.
tree()
    dot()
Finally, two functions are called to draw the Christmas tree. The blinking is continuous, so dot() should be called in the loop.
