Camera RecognitionΒΆ
In this project, we will make a color recognizer, connect a camera module to the Raspberry Pi, use PiCamera and OpenCV to process the objects captured by the camera, and express its colors with RGB Matrix HAT.
This example needs to enable the Raspberry Pi Camera function.
Then install third-party dependencies
sudo pip3 install opencv-contrib-python
sudo apt-get install -y python3-h5py libatlas-base-dev
sudo pip3 install -U numpy
Run the code
When the program is running, hold the camera moduel and aim at some brightly colored objects, you will find that the RGB Matrix HAT also shows similar colors.
cd /home/pi/rgb_matrix/raspberrypi
sudo python3 camera.py
You can Modify/Reset/Copy/Run/Stop the code below. But before that, you need to go to source code path like rgb_matrix/raspberrypi. After modifying the code, you can run it directly to see the effect.
# To run this example, you need to turn on Camera on raspi-config => Interfacing => Camera
# Then run the following command to install dependencies
# sudo pip3 install opencv-contrib-python
# sudo apt-get install -y python3-h5py libatlas-base-dev
# sudo pip3 install -U numpy
from picamera.array import PiRGBArray # Generates a 3D RGB array
from picamera import PiCamera
import cv2
from PIL import Image
from rgb_matrix import RGB_Matrix
rr = RGB_Matrix(0X74)
camera = PiCamera()
camera.resolution = (1280, 720)
raw_capture = PiRGBArray(camera, size=(1280, 720))
# Allow the camera to warmup
time.sleep(0.1)
# Grab an image from the camera
for frame in camera.capture_continuous(raw_capture, format="rgb", use_video_port=True):
    image = frame.array
    # Convert image to 8x8 for RGB matrix
    img = cv2.resize(image, (8, 8), interpolation = cv2.INTER_AREA)
    im_pil = Image.fromarray(img)
    # Render
    rr.image(list(im_pil.getdata()))
    raw_capture.truncate(0)
How it works?
import cv2
  • Import PiCamera to support the use of the camera.
  • Import PiRGBArray to help the Raspberry Pi output the captured images in the form of an array.
  • Import OpenCV vision library where cv2` is the name of the C++ namespace of Opencv.
  • Import the image processing library PIL of the python platform.
camera = PiCamera()
camera.resolution = (1280, 720)raw_capture = PiRGBArray(camera, size=(1280, 720))
Create a PiCamera object and call PiRGBArray() to generate an RGB three-dimensional array with a resolution of (1280, 720) and pass it to raw_capture.
    image = frame.array
Traverse the images captured by the camera and pass them to the image in the form of an RGB three-dimensional array.
Convert the picture into an 8x8 RGB Matrix HAT and pass it to im_pil in the form of an array.
Convert im_pil into a list form to be used as a parameter of rr.image to light up the RGB Matrix HAT.
Clear raw_capture in this loop.
